Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous Bottle heater(NOS brand)
Old Jan 15, 2008 | 12:14 AM
redmaro1's Avatar
redmaro1
Default Nitrous Bottle heater(NOS brand)
So I installed a nitrous bottle heater from Checkers. I paid like 119 for it, the brand is NOS.
SO I installed the bottle heater and it raises my pressure to 600 and then the heater turns off(bottle was open). Why is this heater turning off?
Thanks[&:]
[align=center] [/align]
Old Jan 15, 2008 | 07:41 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Nitrous Bottle heater(NOS brand)
1st off, are you sure your pressure guage is working ?
2nd...is the bottle full ? if there is only 3 lbs or less, you won't get any more than 600 out of it, weight it
finally....there are 2 t-stats on the NOS heater (last time i had that kind) one is the main the other is a backup.....if you bypass the main and only use the backup you can raise the cutoff temp by about 10* so it goes to about 80* instead of 70*, but you have other issues other than , you need to double the temp to double the pressure, thats how it works
also......try to get a temp on the bottle when it shuts off, or just after it has been on a while
i have a feeling your bottle is almost empty
Old Jan 18, 2008 | 03:40 PM
bryanec's Avatar
bryanec
Where are you t-stats placed? I had the same problem, now I tape mine to the lower bottom of the bottle, away from the heater, and it holds a steady 1100 psi until almost empty. I havent taken a temp reading but it gets the top pretty warm.
[align=left] [/align]
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
ChampInSD
Oct 2, 2015 04:55 AM
750BOSS
Wheels & Tires
Sep 18, 2015 06:14 PM
