Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
ATTN N20 USERS!!!!!!
Old Mar 6, 2008 | 07:32 AM
  #31
janine's Avatar
janine
Default RE: ATTN N20 USERS!!!!!!
ORIGINAL: nitrous_bob
ORIGINAL: janine
As far as getting smacked around by an N20 car, my engine puts out enough real HP (on it's own) not to worry about that.
AfterCooledVortech15PSI
hmmmm......what part fo your engine "all by itself" is able to pack 41 poundsof air into it ?of course i'm assuming you have a 2.75" throttle opening.....otherwise it's more
i always like the blower VS nitrous arguments
" i spent more than you did to simply add more air into my combustion chambers....so it must be ok"
" bottles are for babies...real men spend daddys money on power adders"
" if it's that simple....it must be cheating"
" well if you take your bottle out i'll run you"
any more good ones..........
hahahaha !!! just playin
did you know that nitrous cannot...no matter what .....burn, start a fire, or explode ?
it's not flammable in the least bit , it's just an oxidizer , but one that is extremely cold, and separates into it's original particles at the perfect temp for an internal combustion engine.
so those flames you see are not really from a bad tuned car...it's most likely from a leaky fuel line or some other fuel component that broke.
i like blowers too, i just don't care for all the byproducts...mucho extra heat , highcylinder pressure everytime you start it up stressing parts, head unit wearing out and needing to be rebuilt, head gasket issues.
diffrent strokes for diffrent folks i guess
i'm a baby, i'll keep my bottle (and watch everyone else cry about it)
No. I didn't.
Interesting.
There is a lot of misconception about nitrous.
PS -- So when a forced induction motor is initially started, cylinder head pressure occurs thatcauses stress on parts, heads and head gaskets?Do all chargers do this? Or just roots type chargers that give off low end torque -- basically from ignition --as a KB or Whipple.
Vortechs start giving boost after 3000 rpm and the boost comes on gradually, not instantaneously as the Cobra type chargers do. So would a Vortech stress the engine on initial start up? Please clarify this. I can't see why it should, it runs on pure engine until boost hits at whatever rpm 3000 or so....
Old Mar 6, 2008 | 08:32 AM
  #32
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: janine
ORIGINAL: nanaki
ORIGINAL: janine
ORIGINAL: nanaki
mmmm... i can't wait to get my new rear end so i can actually launch the shat out of my car. that janx will surely wait for me at the starting line with the shat in there now.
New rear end? Pea head, what do you have up your sneaky sleeve?Better posi with 31 spline axles? Short Gears?
I noticed your making 498whp. Is that with or without the meth injection?
muwahaha, you'll see!
actually, that's an old dyno sheet. i'm making 593RWHP now on pump. i need to get me one of those mini race bypass valves you have. i'm running 2 mondo's right now, 1 before and 1 after the IC. i took the meth off and just have a 3 core now. just got my 8 rib setup on too. i'm running about 20psi, but i'm fuel limited until i get new rails. grrrrr!
i'm going to take care of my fuel problem first, then i get the rear end.
Vortech Mondo bypass valves are very big -- and you have 2? Why? Where can they possibly fit under the hood? And you want a mini in addition or as a swap?
I just have one mini and it takes care of all surging. Mustang runs very smooth. A fantastic mod.
I have the 8 rib set up too. Had some troubles with it at first. Needed shimming....With it, was able to run 2.78 pulley with not belt slip.
I never did like the meth concept. Just didn't like the notion of depending on a bottle so to speak. But they do work. I know guys who have them. They use washer fluid. 40 plus HP gains.
As far as fuel? I had to go wtih 60lb jects, Cobra Tank, Cobra Ring, heavy gauge wire kit, 1"lineand 2 GT 500 pumps -- a $2600 system installed. I use the fuel rails that came with the FoxLake P51 intake. No troubles.
LMK about your rear end set up!
because it's surging even with the 2. 20psi doesn't like those mondo valves. chris wants to get rid of them and put on the vortech mini race bypass, then put the new fuel rails on and get me some real power. they're shopping around for the best deal right now and are going to get back to me. they have a backlog of cars to take care of too first. couldn't believe i was 7RWHP away from the 600 club!
i got 40RWHP from my old meth kit when i had it on. it's nice, but once i started running ~17psi, chris told me to get rid of it. it's not cooling for shat at the higher boost levels, and isn't worth putting a higher flowing pump on. then i'd be going through fluid like crazy.
Old Mar 6, 2008 | 09:08 AM
  #33
janine's Avatar
janine
ORIGINAL: nanaki
ORIGINAL: janine
ORIGINAL: nanaki
ORIGINAL: janine
ORIGINAL: nanaki
Chris has always looked out for you in your best interests. Your in good hands at Excessive.
Sell those Mondos on Ebay and get back some of your money. You'll like the Vortech mini race bypass valve! It will cost you about $235. Plus labor for the 2 welds. Worth every cent.
600 club. Wow! Now that is borderline insane! But ya gotta love it!
Good luck.
Old Mar 6, 2008 | 01:04 PM
  #34
prochargedGT's Avatar
prochargedGT
i bet you all couldn't be my space ship...
Old Mar 6, 2008 | 01:14 PM
  #35
janine's Avatar
janine
ORIGINAL: prochargedGT
How did you getthe torque numbers aboveHPrunning a Procharger?
Old Mar 6, 2008 | 01:59 PM
  #36
ZW99GT's Avatar
ZW99GT
ORIGINAL: 01snake
does it cost more to get gravity filled?
Not that I know of. It just depends on the shop. The crappy place I was getting it filled cost 2.75/lb and the new shop is 3.50/lb. It's more than worth the extra 7 bucks.
Old Mar 6, 2008 | 07:57 PM
  #37
nitrous_bob's Avatar
nitrous_bob
no it's not more....a fill is a fill.
you really should weigh your bottle too...
the rice guys will stop filling at a certain psi, and call it full. then charge you 10 lbs
when in fact...my bottle always has at least 2-3 pounds left in it when i fill it.
another fact is that psi rises w/ heat....just because it is 1200 psi it's not necessarily full
compressor fills cause big heat and fake bottle pressure that you can't reproduce w/out a torch
they don't HAVE to freeze it...but if they use a compressor they should have it in cold water and at least chill it for a bit and during the fill. just like a SCUBA tank
as far as the blower stuff ??? i have no idea, i'm not a blower guy....i figure when the impeller is spinning it's making boost...not big boost but something
Old Mar 6, 2008 | 09:13 PM
  #38
janine's Avatar
janine
Something, yes. I don'tbelieve a Vortechputs outenough impeller pressure to place stress on internals upon start up.
Old Mar 8, 2008 | 09:43 AM
  #39
68wicked's Avatar
68wicked
Yeah the zex bottles do leak if they freeze um. I had mine filled for the first time and i ended up paying for 7lbs of n20. I was pretty pissed so i asked the guy that filled my bottle to check the o-ringcome to find out there was noo-ring in there so i ended up payingfor the wasted n20 and got a free o-ring outof it.Havent had any problems with it since. Justthought idput that out there in case some onegets a zex kit play it same and put in an o-ring its 2 dollar insurace.
poke68
Dec 16, 2025 03:36 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
BeatnikFink
Oct 1, 2015 08:00 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
