Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Injector size ??
Old Apr 20, 2008 | 11:02 PM
Projectquick's Avatar
Projectquick
Default Injector size ??
I was talking to the guy who is going to be tuning my car after I install the turbo. He recommended 42 lbs/hr injectors for the set up I was looking at. My question is I plan on having the engine rebuilt next year with all forged parts and was wondering if the 42s would be able to handle about 500whp? For right now the kit is intercooled and has a 70mm turbo that I will be running at 6-7 psi. I told the tuner my plans of upping the boost after I have the bottom end ready to handle it. He said that the 42s should be able to handle my power goals. The thing that kind of threw me off was the "should be" part. I want to get the right injector and MAF combo the first time so would the 42s handle my plans or should I go bigger?
Old Apr 21, 2008 | 12:06 AM
Sap's Avatar
Sap
Default RE: Injector size ??
http://www.rceng.com/technical.aspx#...tor_Worksheet_
For 500 hp at the crank you probably want to go with 60# per hour injectors.
E.
Old Apr 21, 2008 | 05:14 AM
nanaki's Avatar
nanaki
Retired MF Moderator
42s should handle 500RWHP, they'd be pretty maxed out though. i had 36lbs injectors pushing 467RWHP, but they were pretty much at their max duty cycle.
Old Apr 21, 2008 | 07:57 AM
floodzilla's Avatar
floodzilla
42s should handle 500. it be a stretch but it would handle the power. anything more id definatly go bigger
Old Apr 21, 2008 | 09:50 AM
OneFastEclipse's Avatar
OneFastEclipse
Look at it this way, if you buy 42lbs injectors, you will be out of injector before too long and be buying something bigger anyway. I recommend going straight to 60s, that way your fuel system will be maxed before the injectors and the price difference is so minimal, it makes sense. Plus, the 60s are probably the best “bigger†injector for idle and drivability.
Old Apr 21, 2008 | 12:30 PM
Projectquick
So for a lets say 475-500 whp set up I should go right to 60 lbs/hr, but they would also work fine at about 400-425 whp for the time being?
Old Apr 21, 2008 | 09:10 PM
OneFastEclipse
Yes, they would work fine.
mltdwn12
Sep 23, 2015 08:54 AM
Demodulates
Sep 18, 2015 11:14 AM
pimp2303
Sep 17, 2015 08:45 PM
uedlose
Sep 10, 2015 01:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
