125 shot with stock pump?
Sure is....Just sprayed mine with a 125 shot. I have a zex wet kit and a fuel pressure safety switch. You will be happy with the 125 shot....it tore the tires off first and second and I have an automatic and 20 inch wheels and tires.
ORIGINAL: lilc1511
how bout a 150? where does it end?
yea im not worried about the engine holding up, it will. i can tune it to run a 12:1 afr and it will be fine... its just a matter of whether or not the injectors and pump can make that 12:1 happen for me...
Im pretty sure with an upgraded pump and a nitrous tune on the dyno it could be done safely but anymore than that is playing with fire. The guys at JBA racing told me they could tune it for a 150 shot no problem. Just upgrade to a focus pump.
It would not be very smart at all to spray 125hp shot with stock pump. IMO I doubt that it will live past a few runs. The car needs to be tuned with an svt focus pump. Would it be cheaper to buy a $75 pump or a whole new motor? Its not worth the risk. Swapping fuel pumps takes 30 minutes for me....
ORIGINAL: Frostbitten
Im running a 125 shot just fine on a stock pump. I also have a fuel pressure saftey switch and no problems so far. Also my live wire tells me my fuel pressure is steady. I would have to say I respectfully disagree....125 is ok on stock pump with a safety switch.
