Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous on stock engine
Old Jun 17, 2008 | 10:58 AM
Fobra's Avatar
Fobra
Banned
Default RE: Nitrous on stock engine
with slicks weight reduction and trick suspension I know of a 415 rwhp centri car that runs 11.2's
Old Jun 20, 2008 | 05:41 PM
SleepingGT's Avatar
SleepingGT
ORIGINAL: Miceleb
To be honest you arent going to benefit much from a 3000 stall with out cams. Maybe a slightly smaller stall for stock cams. The stock bottom end is known to hold up to 150 shot with a tune. I wouldnt push it more than that. Im running a 125 shot right now with no problems.
ORIGINAL: procs2v
Low 11 on a stocklongblock with spray, I don't think so. You can spray up to 150shot. You will need injectors and fuel pump. If you want to go that fast on a 2v you need a built motor and a nice shot or a good turbo system.400-450 is the max. Good luck
be careful of idiot internet racers like these two, the converter will make a huge difference and so will the j-mod, yes you will need the fuel pump for 150 shot but with a wet kit your stock injectors are fine(thats a general misunderstanding of the entire mechanics of a wet kit)
the fastest i know of anyone running on a stock 2v bottom end was Heath on modularfords, he did a 10.8x with 150 shot on perfect suspension and converter set up and H/C/I
running mid to low 11's on a stock bottom end 4.6 isn't unreasonable at all with 150 shot many people do it regularly, going for 10.99 is a little out of reach without really getting every bolt on and getting that suspension tuned just right with significant car weightloss aswell
Old Jun 20, 2008 | 07:09 PM
procs2v's Avatar
procs2v
becarefulwho you call an internet racer. If you think you have something to race me with come on. Where in my post does it say stockbottom end, I said stock longblock. I didn't read where he said anything about a h/c. So yes you are right if he want to go that route, but I thought he wanted a stock longblock like I stated. It's all good.
Old Jun 20, 2008 | 07:31 PM
lilc1511's Avatar
lilc1511
ORIGINAL: procs2v
you may be confused as to what a longblock is.
calm down guys. be nice, we are all friends here!
Old Jun 20, 2008 | 08:13 PM
procs2v's Avatar
procs2v
a longblock means the motor has not be touched, a short block means h/c or just cams.
Old Jun 21, 2008 | 12:31 PM
SleepingGT's Avatar
SleepingGT
ORIGINAL: procs2v
i have stock long block and i'm blowing completely through my converters lock up and still out running your 03 gt with my 00 on 100 shot
Old Jun 21, 2008 | 01:51 PM
procs2v's Avatar
procs2v
ORIGINAL: SleepingGT
ORIGINAL: procs2v
That's nice, but I don't have my mustang anymore. I don't thank you have even been faster than what I went with my mustang.But who caresIf you want to race the vette than you can pm some info and I would be happy to take your money. I think you talk more than you race.
Old Jun 22, 2008 | 09:03 PM
GTRACER88's Avatar
GTRACER88
Ok guys be nice. I will eventually go with stage 2 heads and cams which i will be aiming to the low 11s. Btw im near sea level and i had my stock gt run 13.9 on an auto with 245s. Thanks for the input.
Old Jun 23, 2008 | 07:08 PM
lilc1511's Avatar
lilc1511
ORIGINAL: procs2v
your longblock description is close in a weird way, but your short block is...??? i dunno where you got that
a stock longblock would be:
stock block pistons rods crank heads valvescams intake manifold... and the other obvious thing that go with that...
stock short block would be:
stock block pistons rods and crank...
so basically you were wrong either way because both include a STOCK bottom end.
not trying to be an ***, just clearing it up, we all get confused.
Old Jun 26, 2008 | 01:47 AM
Titled4cyl's Avatar
Titled4cyl
ORIGINAL: lilc1511
ORIGINAL: procs2v
[sm=exactly.gif]
