Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
X pipe ?
Old May 14, 2005 | 09:19 PM
wildazme's Avatar
wildazme
Default X pipe ?
When you change to an x pipe do you have to remove the cats? or do you stock cats stay on? Or are you able to use you stock cats on the new xpipe? i want to gain performance but also maintain my emissions equipment.
Old May 15, 2005 | 12:06 AM
primetime5.0's Avatar
primetime5.0
Default RE: X pipe ?
you can buy an aftermarket high flow x pipe, instead of 4 cats it'll have 2 high flow ones
Old May 15, 2005 | 01:30 AM
josh_0351's Avatar
josh_0351
They come wif em (cats, if you get a catted pipe). If you get an off-road unit, you’re cat-less.
At any rate, your stock unit is one piece and most after-market pipes are to. I know the SLP catted X is a modular unit cause that’s what I run – by modular, you can swap out the cats for race-inserts making you off-road.
Old May 15, 2005 | 01:36 AM
dan's Avatar
dan
The new pipe will replace where your cats previously were. If your worried about emisions just get a highflow X pipe instead of an Offroad X pipe. The highflow will give you basically the same performance as the offroad but will be a little more expensive and will be a little bit more quite (but still louder).
Old May 15, 2005 | 01:56 PM
BicketyBam's Avatar
BicketyBam
The Magnaflow Tru-X crossover pipe I bought was welded in behind the stock converters and O2 sensors. If I went with the crossover pipe with their converters, it would have more than doubled the cost.
ak98
Feb 18, 2023 08:36 AM
Sep 24, 2015 09:18 PM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
wawagner82
Sep 13, 2015 09:02 AM
