Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Lag on a centrifugal supercharger?
Old Oct 26, 2008 | 10:15 PM
  #21
FoxGT's Avatar
FoxGT
Originally Posted by silver91gt
turbo lag is the time it takes the impellers to spool up after you hit the gas.
Not in all cases. It only applies for after boost threshold. If you were to punch it at 2000rpm & you didn't see any positive pressure until 2800 rpm & it takes you 3 seconds to get there, that doesn't mean you have 3 seconds of lag time; that just means it took you 3 seconds to reach boost threshold.
Lag can only be measured from the boost threshold point. So if i see positive pressure at 3500rpm, and i'm at 3550rpm in 4th gear & I floor it, it may take .8-1 second to see positive pressure, so I have .8-1 seconds lag time. Same applies for at 5000rpm, but I may only have a .2-.1 second lag time at 5k.
Old Oct 26, 2008 | 11:35 PM
  #22
vortech01vert's Avatar
vortech01vert
when i had my vortech and 4.10 gears it didnt feel like lag, it pulled good to 3k and after that it really work up. but its nothing like the way it feels when i punch it now with the kb. its really end up on how much you are willing to spend. centris are cheaper and twin screws tend to be more expensive. but either way there both fun as hell
Old Nov 24, 2008 | 11:59 PM
  #23
trublmaker's Avatar
trublmaker
my vortech still gets decent gas milage, depends on your driving style and there is a little lag until you rev it up but then it pulls hard! If you plan on making more power in the future I would go with a cetri blower
Old Nov 25, 2008 | 10:14 PM
  #24
FoxGT's Avatar
FoxGT
Not lag.
Originally Posted by FoxGT
lag can not be measured below that point. If you produce boost at 3500 rpm, you can not measure lag until you get past 3500 rpm.
LAG
Definition: Within a turbocharger's operating range, lag is the delay between the instant a car's accelerator is depressed and the time the turbocharged engine develops a large fraction of the power available at that point in the engine's power curve.
Now it's time to evaluate the turbocharger versus the supercharger according to several important factors.
Cost
The cost of supercharger and a turbocharger systems for the same engine are approximately the same, so cost is generally not a factor.
Lag
This is perhaps the biggest advantage that the supercharger enjoys over the tubo. Because a turbocharger is driven by exhaust gasses, the turbocharger's turbine must first spool up before it even begins to turn the compressor's impeller. This results in lag time which is the time needed for the turbine to reach its full throttle from an intermediate rotational speed state. During this lag time, the turbocharger is creating little to no boost, which means little to no power gains during this time. Smaller turbos spool up quicker, which eliminates some of this lag. Turbochargers thus utilize a wastegate, which allows the use of a smaller turbocharger to reduce lag while preventing it from spinning too quickly at high engine speeds. The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses boost pressure, and if it gets too high, it could be an indicator that the turbine is spinning too quickly, so the wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down..
A Supercharger, on the other hand, is connected directly to the crank, so there is no "lag". Some superchargers are able to produce boost at a very low rpm, especially screw-type and roots type blowers.
Old Jul 18, 2011 | 01:24 PM
  #25
CobraChamp04's Avatar
CobraChamp04
Default Need Help!
Hey, new to this forum didn't know if yall help with problems around her see alot of debating on parts, But maybe someone can help me figure out this issue I am having with my 04 Cobra. Just recently the supercharger started kicking in and out on full throttle. I'm not very knowledgable about superchargers so maybe yall can help. The TC is off and it almost feels like the belt is slipping just on occassion. Any ideas on what to check? THANKS!
Old Aug 7, 2011 | 11:50 AM
  #26
Dr.JZ's Avatar
Dr.JZ
some good advice on here already....you will begin to hit boost in the 3-3500k range typically with a centrifugal....the roots or twin screw will give you instant boost and torque before this, but traction becomes a major issue....and yes, a Vortech or Procharger or Paxton will be loud with the right setup....all three sound awesome at idle
Old Aug 7, 2011 | 07:57 PM
  #27
97stanger's Avatar
97stanger
just an fyi this thread is 3 years old...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
