Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Oil Return System Problem
Old Nov 5, 2008 | 01:11 PM
vanquish's Avatar
vanquish
Well to do that I would need the oil pan off of the car right? Am I better off just taking the pan off or doing it according to vortech's instructions?
Old Nov 5, 2008 | 01:49 PM
Fobra's Avatar
Fobra
Banned
Originally Posted by FoxGT
There's nothing wrong with drilling the pan; i've done it quite a few times on some of my kits, but you do have to have the pan off to clean out the metal shavings & of course using silicone to help seal is a good idea.
I would recommend welding it though.
+1 dont be lazy take off the pan
Old Nov 6, 2008 | 10:01 AM
FoxGT's Avatar
FoxGT
Honestly, the only reason I would recommend using a punch and keeping the pan on would be simplicity for those that don't have the tools to take the pan off. That way you don't get a bunch of metal shavings in your pan as opposed to if you tried to drill a hole in the pan while it's on, in which case you'll get lots of metal in the pan which could cause quite a bit of damage.
The best route would be to drill into the pan & weld a fitting on, the next best route would be to drill a hole in the pan, thread the fitting in, then using a nut on the backside to help hold. I would recommend using silicone if you're not doing the weld route to help ensure you don't have a leak around the fitting.
Old Nov 6, 2008 | 12:38 PM
vanquish's Avatar
vanquish
okay i'll probably do that then. Thanks
djbigskrilla
Sep 20, 2022 01:04 AM
mustangfan305
Aug 31, 2015 07:18 AM
inyadreems
Aug 21, 2015 09:10 AM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
