Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
magnaflow catback install
Old Jun 4, 2005 | 06:49 PM
sandcracker21's Avatar
sandcracker21
Default magnaflow catback install
just wondering, is it possible for me to install a magnaflow catback, or is there welding that i need to do?
Old Jun 5, 2005 | 04:54 AM
Shawn02GT's Avatar
Shawn02GT
Default RE: magnaflow catback install
it should bolt right up to your stock H pipe, no welding required.
Old Jun 5, 2005 | 05:10 PM
pete1665's Avatar
pete1665
its a pretty simple install. You will need to cut off the stock system right above the axel to get it out.
Old Jun 6, 2005 | 09:11 AM
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: Shawn02GT
Old Jun 6, 2005 | 11:55 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
I would have the tips welded on because someone might just steal them and they cost about $100 a peice.
Old Jun 13, 2005 | 05:27 AM
sandcracker21
ic ic thanks
wut about mid pipes?
Old Jun 13, 2005 | 12:14 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
midpipe just bolts up to headers and cat back. just disconnect - battery terminal, unplug O2 sensors, unbolt the cat back first, then lower the midpipe a little then undo the bolts at the headers. doent be afraid to force it out.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
