Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Help!! Boost problems
Old Feb 8, 2009 | 08:57 PM
superchargedyllwstang's Avatar
Default Help!! Boost problems
I just installed a vortech v-1 supercharger with a 3.1 pulley, and treadstone intercooler. I took it to get tuned and its only producing 1.9 lbs of boost?? My recirc valve seems to work good, and I'm pretty sure theres no boost leaks unless the intercooler is shot but i bought it brand new. The head unit is used and i rebuilt it all new bearings and seals, impeller spins good w/ no broken fins and in the correct direction. Any ideas???????
Old Feb 9, 2009 | 12:33 AM
RTtim's Avatar
RTtim
I would start with checking for boost leak. If not double check the pulley. I am not to sure about superchargers and what pulleys you can get for them. That is just where I would start.
Old Feb 9, 2009 | 04:28 PM
pretty positive theres no boost leaks unless the intercooler leaks but i doubt it because its brand new i might have a underdrive crank but it seems like its too much of a drop in boost
Old Feb 9, 2009 | 04:36 PM
NoGo95GT's Avatar
NoGo95GT
The belt should be extremely tight. I just threw mine on and barley tightened it. I made 6lbs, then tightened it a little more and made 7lbs, then did it as much as I could and made 10lbs. After fixing a small leak and added a powerpipe I'm now making 15lbs. I'd check there first.
Old Feb 11, 2009 | 04:35 AM
Obsequious1's Avatar
Obsequious1
+1 ON THE BELT, ALSO, MY RUBBER COUPLER POPPED OFF MY UNIT ONCE, I LOST PRESSURE. I COULD HARDLY TELL THAT IT POPPED OFF THE HEAD UNIT BECAUSE IT LOOKED LIKE IT WAS STILL ON.
Old Feb 11, 2009 | 08:28 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
So what did the tuner have to say? And you're not supposed to run underdrives w/a blown application
Old Feb 12, 2009 | 11:12 PM
i have a new set of oem pulleys coming in because im pretty sure thats the problem. Ill double check my piping as well. Also, i have a spring-loaded tensioner so how am i supposed to tighten my belt??
Old Feb 15, 2009 | 02:19 PM
trublmaker's Avatar
trublmaker
measure you crank pulley and see how big it is to see if you have u/d pulleys,the belt slipping is another poss.
Galactic
Apr 29, 2019 02:56 PM
Oct 7, 2015 07:02 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
