NOS
Different people will tell you different things but most of the companies that make them claim that 100 is about as far as you wanna go on stock guts. Based on that statement you would be fine with a tuned 125 shot. Whatever you do make sure you get a good tune and you have an adequit fuel system. Being stupid on a high shot of N20 can cost you some serious $$. Be educated, do your research, use your head, and youll safely enjoy large quantites of the giggle gas
Depends on if you wanna run Wet or Dry. You should be alright running a 100 shot with a wet kit. If you go Dry (I would recommend dry, safer because no tapping fuel lines and, no worry of fuel puddling) then you need to make sure you have a properly sized fuel pump. This is because with a dry kit the injectors will have to accomidate for adding fuel durring the spraying process.
ORIGINAL: JADAS2001GT
thanks do you know what size fuel pump i would need for the 100 shot dry
