Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
LOTS Procharger ??
Old Jun 24, 2005 | 09:09 PM
Blk_96_GT's Avatar
Blk_96_GT
Default LOTS Procharger ??
I am planing on getting a Procharger p1sc at the end of summer, but i have a few questions, is it safe to run 10/11 psi on a stock motor with 131,xxx miles? The motor is really strong though. If I install the kit myself, will it still be under warenty? The kit comes with a chip, is that for a tune, or what? Will i have to go and get it dyno tuned? If so does any one know some where close to Modesto, CA. where i can get it dyno tuned? How much does it cost for a dyno tune?
Old Jun 24, 2005 | 11:59 PM
BicketyBam's Avatar
BicketyBam
Default RE: LOTS Procharger ??
I'll try and answer some of your questions.
1. I just put a Vortech S-Trim with the stock pulley and a MPH powerpipe on my 2000 GT. I don't have a boost guage, but I'm guessing it's making a minimum of 8 psi. My engine has 136,000 miles on it. Whether you blow up your engine or not really depends on the tune and how much power you try to make. Keep it around 375 rwhp with those miles.
2. Not sure about the warranty, but I don't see why it wouldn't be covered just because you installed it.
3. The car has to be dyno tuned after the supercharger is installed, so yes and yes to those questions. Air/fuel ratio, timing, etc. needs to be set by someone who knows what they are doing. With 130k+ on the engine, this will be critical.
4. I live in NY, so I can't help you there.
5. At least a few hundred bucks. I paid $550 to have my kit installed and that included all the dyno runs and tuning. It was on the dyno for over an hour. Best $550 I ever spent.
Good luck!
Old Jun 25, 2005 | 01:26 AM
Blk_96_GT's Avatar
Blk_96_GT
thank you, i was going to blockbuster and i saw a car that had a "Performance Dyno Tuning" sticker on it and they are located in oakdale which my GF lives there any ways so ya, and it will cost $100 for a dyno tune, (does $100 sound cheap for a dyno tune?)i dont know how well there work is, but i went on thier web page and they have a lot of cars that make good HP so i am guessing they are probably good.
Old Jun 25, 2005 | 02:11 AM
BicketyBam's Avatar
BicketyBam
$100 is dirt cheap for a dyno tune, which would scare the crap out of me. Remember, you don't just want a tune to give you the most RWHP, you want one that gives you the most AND the safest RWHP. I'd look for a place that has plenty of experience with the 4.6l mod motor.
Old Jun 25, 2005 | 03:12 AM
nanaki's Avatar
nanaki
Retired MF Moderator
you're probably running 10psi with that powerpipe, bam.
Old Jun 26, 2005 | 03:46 PM
Blk_96_GT's Avatar
Blk_96_GT
i want a tune that will keep my air/ fuel raito in check.
Old Jun 26, 2005 | 06:13 PM
Acer2428's Avatar
Acer2428
Site Mod
Have you looked at power #'s for non-pi s/c'd GT's?
It's just sad. Do the PI swap, THEN do a blower.
Old Jun 27, 2005 | 01:08 PM
BicketyBam's Avatar
BicketyBam
ORIGINAL: Blk_96_GT
You sure do. I put a Dynojet Wide Band Commander A/F gauge in with my s/c. Under normal driving conditions, it reads around 14. When I floor it, it lowers right down to 11.5 and stay there. I configured the warning light to come on if the throttle is > 95%, RPM is >3000 and the a/f is leaner than 12. It gives me some sense of security.
A good tune is key. A good gauge gives you some peace of mind.
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
baddog671
Jul 26, 2016 01:20 PM
14gt_Track
Oct 1, 2015 02:47 PM
Sep 27, 2015 03:16 PM
