Propane/NOS
Hi guys.
First time posting in this section. Im running a edelbrock plate system on my 5.0 in a 65 mustang (pictured below). I have the system completely installed but am not going to run it until I take it to be properly tuned for the shot. starting with a 50 shot but will have a 100. I talked with an old race guy that was reccomending that I run propane as a stand alone system. Seems like it would be simple to do instead of running a T off my gas line now. Also it would help a lot with octane since I live in cali and can only pump 91.
I guess my question is how would you regulate the pressure coming off the propane bottle? And do I use the same fuel selenoid even though it will now be running gas through it? What are your thoughts and does anybody have any experience with this?
Thank you,
Dan
Thank you,
Dan
i have never heard of anyone using propane as an octane booster. youd be much better off running a stand alone meth tank thatll spray methanol into the motor instead of just regular fuel. even that is over kill. your talking about a tiny little 100shot of nitrous. 91 octane will be more then enough, just pull a couple degrees of timing and youll be fine. even with a 200 shot 91 octane is fine, its all in the tune. your making a mountain out of a mole hill. and not sure where in california you are, but there are a couple stations in my area that sell as high as 105octane at the pump
Yeah - thats a diesel thing. Old tricks are fine - but imagine how much money companies spend researching the products they sell you these days. Get a kit they work.
Propane won't work on a gas engine. Thats a diesel trick.
you don't need a tune on a 5.0 w/ nitrous
by that i mean you don't need a chip or anything. just pull a degree out for evey 50 hp worth of smack
i use stock plugs gapped at .042 for 80-100 shot and 89-91 octane depending on if it's hot or nice and cool
if it's over 85* and i'm going to the track... i'll top off w/ 94 but when i just happen to be on the street and catch a race... i'll squirt 12-14* of timing on 89 octane w/ my 80 jets. never had a problem and i have been on a dry kit for over 10 years now
