Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
UPR X-Pipe
Old Jul 16, 2005 | 06:41 PM
4.6guru's Avatar
4.6guru
Default UPR X-Pipe
I am thinking about getting the UPR x pipe for $164 that includes the 24" O2 extenders. This seems like a pretty good deal. My question is regarding the mil eliminators. I have 4 O2 sensors but I only need two (1 pair) of eliminators...is this correct? And are the mil eliminators for the front fo rear sensors? Also, does the UPR pipe have a ball and socket design that makes it easy to put together and take out? If I don't have to use gaskets each time that would be great (because i will need to take it out every other year for smog). Can you guys just tell me what you think about this UPR?
http://www.uprproducts.com/shopping/shopexd.asp?id=724
Old Jul 16, 2005 | 07:36 PM
mk636's Avatar
mk636
Default RE: UPR X-Pipe
The price is right, but it won't last like Stainless steel. I don't know what year car you have, but I have the ball and socket at the cats and the driver side manifold. The passenger side manifold is a flange with a gasket. Not sure about the Mils, mine is catted.
Old Jul 16, 2005 | 11:38 PM
primetime5.0's Avatar
primetime5.0
i have a UPR x pipe for my 5.0 and it has great quality as for the mils for you car they go on the last to 02's nearest to the mufflers you only need 2
Old Jul 17, 2005 | 12:18 AM
4.6guru's Avatar
4.6guru
So if I buy an x-pipe that has the ball and socket ends will I not have to worry about using gaskets?
Old Jul 17, 2005 | 01:08 AM
primetime5.0
the driver side is the ball and socket design but the passenger uses a gasket which can be resued a couple of times
Old Jul 17, 2005 | 02:13 AM
4.6guru's Avatar
4.6guru
So what I'm getting at is that I will need to be able to dissmantle the x-pipe and put it back in several times, will I be able to do this? As for the gaskets, where can I find replacements? I appreciate the help.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
firecoyote
Sep 27, 2015 02:37 PM
UPRSharad
Sep 8, 2015 03:46 PM
11GTBlu
5.0L V8 Technical Discussions
Aug 10, 2015 05:56 PM
