Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Intercooler info?
Old Jan 20, 2010 | 10:57 PM
AtotheZ03GT's Avatar
AtotheZ03GT
Default Intercooler info?
Hey guys, I have been doing some research as I plan to supercharge my 03 GT and am still unsure on what all is needed to run an intercooler. First off i plan on using a vortech headunit and would like to install an intercooler right off the bat instead of runnin it without one. I have checked out some of the stickys about intercooling a vortech blower and am still unsure of what all is needed. Would i need to buy an aftermarket coolant tank and other hoses etc....? It seems like a good diy fmic kit from ebay will do the job just fine after reading a lot of the comments by you guys who went that route. Hopefully you guys that have succesfully installed and are runnin a set up similar to my desired one can chime in here and hit me with some knowledge. Thanks for all your help.
Old Jan 21, 2010 | 09:59 PM
school boy's Avatar
school boy
i will be doin a water to air setup in the spring, too cold to be messin with it now.i'll try to do a write up cause its a custom setup
Old Jan 21, 2010 | 11:24 PM
luckythirteen13's Avatar
luckythirteen13
for a a/a intercooler, you need:
the intercooler
a pipe kit, or two
hose clamps, preferably t-bolt clamps
pipe couplers
what you need to do is determine the route the piping will take from the vortech, to the intercooler then back up to the tb and order the piping needed
Old Jan 22, 2010 | 08:14 AM
rthouck's Avatar
rthouck
Well he said ^^^ doesnt get any simpler than that. Altough if you had to ask are you sure you can tackle this?
Old Jan 22, 2010 | 11:18 AM
AtotheZ03GT
Thanks luckythirteen13 I was hopin you would jump in here. Yea I think I can handle the install, I just noticed that a lot of the guys with intercoolers have some kind of extra "expansion tank" or "supercharger coolant reservoirs" if it is an intercooled set up and wasn't sure if that was needed or just an extra goodie under the hood. Thanks for clearin that up guys, If anyone has some spare time to post some pics of your engine bays that would be helpfull. Thanks again.
Old Jan 22, 2010 | 08:40 PM
luckythirteen13
the tanks your seeing are probably because the car has a air/water intercooler.
https://mustangforums.com/forum/pipe...ith-video.html
here is my build thread, i know our cars are different but you can still get some ideas about how the piping can be routed
Old Jan 27, 2010 | 03:16 PM
mustang51js's Avatar
mustang51js
you will need a IAT sensor(intake air tempature) relocation kit if your going with a lightning MAF.Its easy to install all you do is splice 2 wires. What are your goals with the hp as i can tell you the mistakes i made if your going for the hp that i have
Old Jan 27, 2010 | 04:16 PM
school boy's Avatar
school boy
mustang51js, hows your bottom end holdin up to the hp your pushing? how long has it been holding?
Old Jan 28, 2010 | 07:24 PM
mustang51js
so far so good,its been like that for about 3 months, the tuner said i should be good as long as i dont go anymore, he's seen them go up to 450rwhp but thats a crap shoot.Over the next year will be the test for it because i plan on going to the track often and will be driving it much more and harder around town. I also heard that the rods should hold up better if you dont let them get to hot as in letting them cool down and not hot lap it at the track.To me i plan on changing the block so if it goes it goes.I'll post up if it does so keep a look out, hopefully i get a good amount of time in and it may never blow.I guess its a gamble at anything 400 and up on the stock block
Old Feb 2, 2010 | 10:58 AM
zero2005's Avatar
zero2005
what track do you go to? who's your tuner?
