Injector size
if you have the fmu you can run 24s just make sure the fmu has the calibration disk in it for 24s. if you dont have the fmu you will need 42# injectors. its better to run the 42s without the fmu then 24s with. you will also need a 255lph pump in the tank
24lb will definitely not be a good idea. You will run out of fuel at higher RPM's and lose power.
I'd suggest going with at least 39lb, but, you might as well get 60's just in case you up the power anymore. 60's are good for 650 or so HP, and you should be good. 39's are good up to about 400-425, and 42 up to about 500 or so.
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
