S/c questions
Im in the process of building my car with a paxton blower amd im pricing everything out. The kit comes with:
Novi 2000 Supercharger
1/2" Thick Billet Aluminum Bracket
Cast Aluminum Discharge Tube
Fuel Control Unit
In-tank Fuel Pump
Programmed Computer Chip
High-Flow Air Filter
By-Pass Valve
Oil Lines
Radiator Tube Relocation
All hardware and Fasteners
Instruction Manual
My questions are:
1. Do i need bigger injectors?
2. Do i need a bigger MAF?
3. Do I need Bigger Fuel rails?
4. What spark plugs do i need?
5. Is there anything else i need?
Fuel Control Unit
In-tank Fuel Pump
By-Pass Valve
Oil Lines
Instruction Manual
My questions are:
you need bigger injectors,at least 39lb,i was told to get ngk tr6 spark plugs,fuel rails are good, and as far as maf stock is fine as long as you dont go to high,think up to 360-380hp,i recommend getting an intercooler,then you would need a better maf and a ait sensor relocator. But then you would need a dyno tune with that stuff
heres everything it comes with:
Fuel Control Unit
In-tank Fuel Pump
By-Pass Valve
Oil Lines
Instruction Manual
I was planning to go with the tr6 plugs, 42# injectors and one of the sct mafs. What do you guys think?
Fuel Control Unit
In-tank Fuel Pump
By-Pass Valve
Oil Lines
Instruction Manual
that looks like everything you need except for the iat sensor relocation kit, you need that because the maf's on stock have in them but the aftermarket ones dont, plus its better to have the sensor close to the throttle body after the intercooler,all you need to do is drill a hole in the pipe right before the tb and crimp connect the wires.
