Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Please help with dry nitrous
Old Aug 6, 2005 | 05:10 PM
StevenP450yfz's Avatar
StevenP450yfz
Default Please help with dry nitrous
I have installed a dry nitrous kit (zex) 75 shot and there is two hoses that I do not know where they go, well I know where they go but There is no place to put them there? One is supposed to go to the intake plenum and the other to the fuel pressure, if you have done this before let me know where to put them please,and also where the WOT wire goes to I found the tps wires but dont know which one it uses.
Thank You,
Steve
Old Aug 6, 2005 | 05:17 PM
99saleen351r's Avatar
99saleen351r
Default RE: Please help with dry nitrous
What is hooked up then if there is 2 left still??One needs a tee fitting off the fuel rails and the other goes in the intake tube with a nitrous nozzle
Old Aug 6, 2005 | 10:23 PM
Jglisson's Avatar
Jglisson
Cut the vaccuum line running from your fuel pressure regulator (driver's side of the engine) to the intake manifold (center front of throttle body). It should be a small plastic vacuum line, red in color.
Run one vaccuum line from your SMART box to the pressure regulator and the other line from your SMART box to the vaccuum port on your TB.
The white wire splices into the middle wire of the TPS harness. IT should be a gray w/white stripe. Check for leaks, etc.
Email me if you have a problem. Do you have the ZEX instructions?
jglisson@bellsouth.net
Old Aug 6, 2005 | 10:24 PM
Jglisson's Avatar
Jglisson
He is running a dry kit. He shouldn't have to tee into the fuel rails.
ORIGINAL: 99saleen351r
Old Aug 7, 2005 | 12:59 AM
StevenP450yfz
Well I was told tonight that it was not going to work because I dont have a return style fuel system, but I dont know if they knew for sure If anyone has done it and knows for sure that it will work let me know, and also keep in mind that this is not a specific kit for my car and the directions I got from Zex.com are kind of generic.
Thanks
Old Aug 7, 2005 | 01:03 AM
StevenP450yfz
And also Saleen351 what are you talking about??????????????????
Old Aug 7, 2005 | 11:01 AM
Jglisson's Avatar
Jglisson
What year/motor 'Stang are you driving?
Check out zex.com > store catalog > dry kit application guide > open in jpeg,pdf format. Check and see if you stang is on there. I know for a fact it works on 94 - 2003 GTs.
Old Aug 7, 2005 | 04:25 PM
99saleen351r
ORIGINAL: Jglisson
Oh ya ....being stupid I guess
b8checker
Oct 8, 2015 12:55 PM
Dan04COBRA
Sep 30, 2015 11:46 AM
b8checker
Sep 30, 2015 07:11 AM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
