how much faster
im already running 12.8 at 108 with 5 psi.. if i were to spend the money to get injectors, maf, and 10psi.
how much faster is the car really goign to go... i guess im trying to figure out if its worth it??
i forget the formula but believe for every additional psi you gain 6% more horsepower however, more psi you add less efficient it becomes.
Increase from 5-10 psi, I would guess that you would yield close to 25-30% gain which is very noticeable and you won't need to rev car as high to make same power level as your current setup.
You will be yielding another 70-80 rwhp or 100 hp therefore all things being equal and you got traction should put you in high 11s.
Oct 5, 2015 06:07 PM
KingRando
Oct 1, 2015 11:16 AM
