Vortech A trim
Im not sure on the pully size, but if you do pulley that A-trim for 10psi you should also stock up on rebuild kits. Your definatly going to be overspinning it. If you pulley it for 8psi, you could run a UPR boostmaster pipe (if it isnt a direct fit you should be able to modify it to work) and be upwards of 10psi with that.
Do you have a power pipe on it??If not go to Andersonford.com and buy one that should give you a couple pounds more.Best way to get more boost is upgrade the head cause the A-trim is to small do and upgrade to a S-trim and you'll see big gains
Sep 16, 2015 07:53 PM
