Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Supercharger
Old Dec 27, 2003 | 12:53 PM
yellow4.6's Avatar
yellow4.6
Default Supercharger
Can a 4.6 handle 8 pounds of boost (350hp) with stock internals and a stockauto tranny? Or do I need to ugrade rods, crank and transmission? Thanks.
Old Dec 27, 2003 | 04:35 PM
Dan04COBRA's Avatar
Dan04COBRA
I believe with a proper tune, 4.6 GT's are good for 400hp. But that's pushing it...
Old Dec 27, 2003 | 05:22 PM
Jugador1's Avatar
Jugador1
I ♥ Acer
id at least upgrade the rods if i was going over 5-6 lbs, but if you're in there, might as well do it all up. you shouldnt have problems, but if you're going for such a risky (kinda)number why not do it up and crank up the boost to 10-11 lbs
Old Dec 28, 2003 | 03:10 PM
yellow4.6's Avatar
yellow4.6
The Vortec web site claims that with their system, 6-8 pounds of boot 364hp 371ftlb on a stock engine is safe. That is the power I want, but is it safe?
Old Dec 28, 2003 | 03:45 PM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
shouldn't have a problem.. i would drop a transgo shift kit on that tranny..
Old Dec 28, 2003 | 04:31 PM
BlueStang225's Avatar
BlueStang225
i would tweak the trans a lil and other than that you should be ok. but if your doing it you mine as well make sure it isn't gonna f**k up b/c when u add more then you will have to change anyway. if i had the money i would take the right steps! good luck man
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Gene K
Oct 21, 2015 11:37 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
