Good Kit?
does this look like a good nitrous kit? how many passes do u think it will give me ( and id also like to know...whats the typical amount of Nitrous used for one run)? http://www.mustangtuning.com/vev5renikit.html lemme know what u guys think about it....
i think you'd be lucky to get 1 full run on that. it's only 10 oz.
thats like a "sneeky pete" kit that is good for 2 tenths on 3 runs
a 10 lb bottle w/ 100 hp jets will get u about 10 full runs on a full bottle if you heat it all the time, and squirt all the way.
the bottle pressure is pretty innefective when you get to 3/4's low.....lucky to make 40-50 hp on 100 jets
ORIGINAL: nanaki
if you want simple, get a ZEX kit
installation consists of, 1. mounting the box(2 screws, the box has EVERYTHING in it)
2. mounting the bottle(4 screws)
3. running the nitrous line, (drop through the drain hole in the trunk and zip tie it to the frame rail...or existing fuel lines)
4. tapping the tb (put a rag inside it, then drill and tap it, so when you pull out the rag, all the debris follws it)
5. mount the nozzle (screws in your tapped hole)
6. wire everything (tps wire hard wires to tps, power to the batt unless you want switched power, which goes to the switch, then grounded, then 1 to the box)
7. vac lines (remove existing vac to fp reg, replace that 1 and the other to the intake)
thats it , in a nutshell.
Insidian
Carolina Regional Chapter
Sep 8, 2015 05:33 AM
Sep 1, 2015 08:16 PM
