Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nos
Old Dec 27, 2005 | 03:51 PM
Jared_blown5.0's Avatar
Jared_blown5.0
Default Nos
Where can i find a good cheap nitrous kit for a 94 mustang gt?[&:]
Old Dec 27, 2005 | 07:10 PM
Tim37's Avatar
Tim37
Default RE: Nos
jegs and nitrousdirect.com are both sponsers.
Old Dec 27, 2005 | 11:10 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Nos
you want new or used?
new go w/ the zex or NOS, about $500
used go to any of the mustang forums w/ for sale ads.
http://www.corral.net
http://www.stangnet.com
http://www.californiafords.com
$250-$300 is average price for a clean used kit, w/ not much extras...maybe a heater or purge.
Old Dec 28, 2005 | 12:19 AM
Jared_blown5.0
Default RE: Nos
thanks bob, my next question to you is... how safe is it to buy a used nos kit? does anything usually go bad with them.. i am new to the nitrous scene and i appreciate your help.
Old Dec 28, 2005 | 12:49 PM
Tim37's Avatar
Tim37
Default RE: Nos
solinoids go bad form time to time.
Old Dec 28, 2005 | 03:44 PM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: Nos
just get a kit from nitrousdirect.com . i actually went to that site and they have some CHEAP kits. any kit will work great if hooked up properly.
Old Dec 28, 2005 | 05:22 PM
Jared_blown5.0
Default RE: Nos
ok next question.. wet or dry kit? which would you guys reccomend and why?
Old Dec 29, 2005 | 04:33 AM
nitrous_bob
Default RE: Nos
ORIGINAL: Jared_blown5.0
uh oh.......this one can start an argument but,
generally if your spray about 100, i would go dry.
if 200+ then wet...and a direct port, or plate kit that goes UNDER the upper intake.
reason is, that a wet kit sprays fuel into the upper , and the upper is noa relly smooth cast, nor is it designed to flow fuel.
so you get puddling and if it backfires...you can pop your hood off.
personally i wouldn't spray a dry kit beyond 125-150....100 shot is perfect for most people.
and about the used kits....selonoids can go bad, but usually don't (they can be rebuilt for about $30, replacd for about $65)
everything else is basic....i'm comfortable buying a used kit, try to find one that is pretty new and looks clean.
if it's all beat up..it might be older , and been through a few hands.
a really clean bottle will be pretty good evidence, it was hardly used, and probably not heated w/ a torch
but always use a line filter....especially w/ a used bottle
Old Dec 29, 2005 | 08:40 AM
nanaki's Avatar
nanaki
Default RE: Nos
dry is easier to install (from what i've heard. never done it myself). code3gt ran that 125 dry shot (with 150 here and there) basically untuned with no problems. i wouldn't go higher than 125 with dry. i actually wouldn't go higher than 125 with either type of kit personally. just get whatever kit is cheapest and get a flip chip with a nitrous tune. SCT makes a neat little 4 (i think it's 4) bank chip.
Old Dec 29, 2005 | 02:27 PM
Jared_blown5.0
Default RE: Nos
ok thank you guys alot, 2 more quick questions then i am done. How much does it cost to fill a 15lb tank, and how long will that tank last??
