Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Need Help: Blowing Gaskets
Old Jan 19, 2004 | 12:04 AM
ledzep's Avatar
ledzep
Default Need Help: Blowing Gaskets
Hi newbie here. I have a 93 5.0 mustang, and for the 2nd time since Ive had the car, 1500 miles, the water pump gasket blew out. The car has a DSS 306, edelbrock heads, upper and lower intake, a vortech s/c, and a bunch of other smaller stuff. The car doesnt run hot, just seems to blow out the water pump gasket when your really getting in it. Anyone have any idea why? Its a pain in the *** to keep having to replace them. Thanks for your help.</P>
-Daniel</P>
Old Jan 19, 2004 | 10:57 AM
vfast's Avatar
vfast
I ♥ Acer
I think you may have a leaking HG. I had a car when I really leaned on it with 20psi it would lift the head up off the block...so it may be building pressure in the coolant system..what psi is the stat cap?<edited><editID>vfast</editID><editDate>38005.3739467593</editDate></edited>
Old Jan 19, 2004 | 08:44 PM
ledzep's Avatar
ledzep
The cap is 16 lbs. The car is making 9 lbs of boost. The oil is clean, and the head gaskets are recent.</P>
-Daniel</P>
bradleyb
Nov 27, 2015 07:50 PM
Dathan
Oct 5, 2015 05:52 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
wraith777
Sep 28, 2015 10:49 AM
