Gears
I think I might go with the 4:10s but I dont know what I will get for gas after that! this is my daly driver so I need somewhat good mpg. what other parts should I look at doing if I am taking the time to change the gears?
ORIGINAL: TimmyGt
people will tell you to get 3.73's or 3.55's for the gas mileage and that your still getting a great improvement in gear.
although thats true...it's not like your gonna still knock down 20 mpg on the freeway w/ 3.55's
it's directly proportional to the gear, how much mileage you lose, and how much stronger your car will run.
to give you an idea, my buddy had his 5-speed notch and went 3.73..on 26" et streets he said it was weak. and needed more.
i used 4.10's on my '89 and have them for my '93 notch.
my '89 went 13.60's...100% BONESTOCK w/ 4.10's and et streets.
the next spring it went 13.20's by deleting AC and smog, and adding LT's and flowmaster catback.
on the 100 shot NOS 5115 kit jetted at 75 , it went 12.50's
not too bad for a bonestock motor.
w/ 4.10's expect about 18 mpg on the freeway and you'll tach about 3000 @75-80 mph
in the city , you could (but probably won't) gain mpg...as you can get into higher gears more often.
i used to go through the traps at about 5200 rpms which is about perfect.
Everyone has been talking about what happens to the 5 speed with different gears, but my question is how would adding a 6 speed to a stang affect acceleration, etc. and what ballpark ($) would you be looking at to get a 6 speed put in? Also (kinda a newbie question) would going to 4.1's lower your top speeddramatically compared to stock (not in a drag racing sense but just top speed period)?
ORIGINAL: orion6g
thats 1 of my 2 dreams for my mustang (the other dream has to do with a 5.4 turbo).
