Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous
Old Jan 27, 2004 | 02:50 AM
dropTopSnake's Avatar
dropTopSnake
Default Nitrous
Has anyone put a dry NOS kit on their car? If so, was it worth it? Also, how much does it cost to fill a 10 lb tank of Nitrous, and where can you ususally find it?
Old Jan 28, 2004 | 05:46 AM
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Jan 29, 2004 | 03:44 PM
dropTopSnake
Default Nitrous
thanks for the info....</P>
The kit I am looking at was features in I think the August issue of MM and FF, it gave a stock 98 auto GT over a hundred more HP at the wheels, now that kit included a new fuel pump made to supply more fuel when the N2O was being used... is that what you mean by the fuel switch?</P>
</P>
Old Feb 1, 2004 | 04:08 PM
Mystic Cobra 96's Avatar
Mystic Cobra 96
Default Nitrous
put a nitrous express wet kit adjustable 35-150 put the 150 shot in and retard yer timing and change yer pugs youll be fine....texas mustangs has it for like 500.00$
Old Apr 27, 2004 | 04:49 AM
2000GT4.6's Avatar
2000GT4.6
Default RE: Nitrous
ORIGINAL: Mystic Cobra 96
150 seems like alot for this car. I dont think I would attempt a often used 150 shot on a stock mustang, even with timing and plugs.
I could be wrong, but I thought the maximum safe stock car shot was around 100?
Old Apr 29, 2004 | 04:45 AM
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Apr 29, 2004 | 12:44 PM
stang574's Avatar
stang574
Default RE: Nitrous
If you have never sprayed before, start out small and work your way up to a bigger shot. It’s better to work out all the bugs and get things right before you go hog wild with the juice. You need to be realistic about your power goals. Beside when spraying 150-plus, you'll find out quickly the coefficient of friction limitations of your tires. Another thing to consider if you’re on a tight budget is when spraying bigger shots your going to be refilling your bottle more often.
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
