O/R X-pipes
So if i buy the Magnaflow Catback system (http://mustangtuning.com/maca94gt.html) and want no cats I buy the O/R X-pipe(http://mustangtuning.com/x.html) Correct? Sorry, I am a big noob with exhauts, I just love the sound and know the companies.
ORIGINAL: V8Cody
Another noobie here...
1. So the only benefit of an no-cats (O/R) instead of high flow cats is about 1-2hp?
2. Am I correct in saying x-pipes are used to simply equalize pressure between the two sides?
3. If so, what is the true benefit of this?
4. Do people run Cats with an x-pipe or is that counterproductive?
Still a newbie... but learning more everyday...
Hope you don't mind the grilling!
ORIGINAL: 6606stang
2. Pretty much.
3. By letting the exhaust gasses between the 2 banks intermingle, you make more power and torque by balancing pressure differences.
4. Catted aftermarket midpipes all come with high-flow cats which are a lot less restictive than the stock cats. So no it is definite a lot better to have high-flow aftermarket cats than the stock restrictive cats.
Gotcha... so you for instance, currently you have an SLP Loudmouth Catback system but are looking to add an H/X pipe, right?
1. Will the H/X-pipe replace your Cats or does the H/X pipe come before the Cats?
Please pardon my **** questions... I'm just really interested in learning about this and it's hard to find people (or a shop) that will give you a straight answer.
Thanks again,
Thanks again,
