Single Turbo Kit
ORIGINAL: FoxRod
That's what I meant. Sorry if it came out wrong. I meant yes the twins will spool slightly faster, but not toooooo much faster. But the single will just give the raw power to help pull you hard once in boost.
ORIGINAL: Tim37
they make a single and foxrod is right a single is more eficient but i was under the impression that on a low boost app 5 to 10 psi you could spool out two small trubos faster than one large ont but you wouldn't be able to make the numbers with a twin set up that can be made with a properly sized single.
Hellion Power Systems.. It say 5k nearly 6k for Single Turbo Kit.. Hell freaking HP Twin turbo kit is on MPH for 6k or so might as well just buy that.
Yeah it's funny. Fox Body's have options for both but the round bodies have a hard time finding that kinda stuff. Anything about boost is gonna cost you an arm and a leg if you want a quality product. Like you can get a Powerdyne real cheap, and there not bad, don't get me wrong. But they don't have a rep. like Vortech, Procharger, or Paxton.
But for all those that want a Turbo don't jump into it like I did. Do some research. Upkeep on your car as well as tuning and things of that nature need to be watch more carefully and done more often. I was stupid. But I'm learnin everything that I can right now so not to F*ck anything up.
yea, i have been looking in to it. I have read over three books on turbos, superchargers and nitrous. I wanted to and still want to learn as much as i can about the three before they are even considered in my car. I want a turbo for my stang, even though their tempermental, as doing as much research as i did, it seems like the best option for my stang. The stangs gonna be my daily driver, but i want a daily driver with some *****, more then it does now.... Im currently looking for a fox body, one with just the body in decent condition. Im gonna make that a drag car. When i find one thats right, want to do a 347 stroker crate motor and a nasty shot of nitrous(200-250) since the compression on strokers is so low and the engine will be forged so it will be able to handle it....
Well just make sure when you do your stroker you get a good block and not a crappy Ford Block. I'm sorry I love Ford but they just don't get it, when it comes to building a strong block. What is with this 2 bolt main sh*t? If your gonna spray or boost hard, make sure to get a DART block.
ORIGINAL: FoxRod
ORIGINAL: FoxRod
Actually the single is more efficient and allows you to attain higher amounts of boost while still spolin fast. Think about it. 4 Cyl cars have a single set up and they still have lag. Now your suggesting doing the same thing twice cuz you think it'll spool fast. Wrong. 8 Cyl going into one turbo will spool just as fast if not faster unless you have a HUGE turbo. But even in that case you won't have anymore lag than a TT setup because you'll have 8 cyl pushing one turbo. Why do you think Supras go to a single setup? You can produce more power. Just some food for thought.
If you're going to have a problem with a twin setup not producing enough pressure then you must have a pretty built engine. These setups can produce well over 100psi on an engine. I highly doubt you're going to be building an engine that can withstand that.
theres no reason to compare single to twins, they can be made to perform identically, want a single to spool fast? use a smaller turbine housing or a/r ratio
properly choose compressors and singles wont be any more efficent as twins
i mean really now
twin setups are no more efficient than singles, any pressure loss in the crossover pipe is meaningless b/c yo can account for it with turbine size and a/r ratio, how do you think remote mount turbos work with little lag
i mean really now
ORIGINAL: klapdout
ORIGINAL: klapdout
i mean really now
i mean really now
ORIGINAL: klapdout
