S197 Classifieds 2005 to 2009 Models
S197 Coil Overs, Pedders
Old Nov 25, 2009 | 04:57 PM
ShawnAlexander's Avatar
ShawnAlexander
Default S197 Coil Overs, Pedders
These have only been on me car since April. 2009, they are practically brand new!! These are adjustable for both ride height and 30 way adjustable for damping. They come with everything you need to install including camber plates. They have been disassembled, cleaned, inspected, and reassembled. They are perfect. Here is what you will find on the PeddersUSA.com website:
Fits Mustang 05-09 and includes Camber plates
Pedders SportsRyder brand has been synonymous with high performance dampers for decades. Pedders SportsRyder shock absorbers and struts combine the most advanced technology with Pedders? renowned expertise in the fine tuning of damping rates for superior handling while maintianing close to OEM ride quality. At the forefront of sports suspension is Pedders eXtreme XA, height adjustable coilover built to Pedders stringent quality standards. Pedders eXtreme XA features sports calibrated tunable damping, motorsport coil springs individually tuned to suit each application and a host of other high performance features including engineered OEM compatible bracket. The eXtreme XA is the pinnacle of performance suspension technology. Height adjustment is achieved by turning the entire coilover into the lower clevis. The 2mm preload on the coil remains the same regardless of height. The range of travel remains the same regardless of the installed height. As the spring perch is not the source of height adjustment and the spring preload remains the same, ride quality is identical at minimum drop and maximum drop. The Pedders Sports Ryder eXtreme XA adjustable coilover range features 30 Position Adjustable Bound and Rebound Damping with a positive CLICK. These are positive Click-to-Tune positions. There is no guess work or doubt as to the setting. You can feel each click as you adjust the damping. How good is it --Driving with eXtreme Xa Coilovers is better than ___. DO NOT USE AIR GUN ON Xa COILOVERS. THIS WILL DAMAGE THE PART AND VOID THE WARRANTY
Retail $1,749.99 EA
Times are tough, buy used $800!!!! SOLD!!!!! SOLD!!!!!
Shawn Alexander
shalexan@yahoo.com
Attached Thumbnails S197 Coil Overs, Pedders-3k53me3pd5o25ta5pe9b49e672dfcfb7f18c8.jpg   S197 Coil Overs, Pedders-3kd3pd3l35qa5t15rd9b4908d882abd071814.jpg
Old Nov 26, 2009 | 08:10 PM
ShawnAlexander
Talking
Bump to the top, please.
Old Nov 27, 2009 | 12:59 PM
ShawnAlexander
Here is a pic of the car with these coil overs installed. You can put the car a bit lower than this, but then the roll center will off. The car corners flat, you won't be disappointed with them. Great price to.
Old Nov 27, 2009 | 01:16 PM
bergie2326's Avatar
bergie2326
PM sent ....
Old Nov 27, 2009 | 02:06 PM
ShawnAlexander
Pm replied to. And Email sent
Old Nov 29, 2009 | 07:23 AM
ShawnAlexander
still available
Old Nov 30, 2009 | 11:46 AM
ShawnAlexander
SOLD!!!!!!
Thanks Adam, enjoy them.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
mungodrums
Oct 7, 2015 04:01 AM
SteelerNation82
Sep 16, 2015 07:11 AM
jaiidutch
Sep 14, 2015 10:29 AM
