Swaybars Question
Old Jul 27, 2006 | 12:27 AM
orion6g's Avatar
orion6g
Default Swaybars Question
I'm considering getting the helwig sway bars but am worried as the roads where I live (Northern Canada) are fairly rough with quite a few frost-heaves in the roads and I'm wondering if sway bars would make the car want to "hop" more over bumps and especially make the back end want to swing out in turns (on bumpy roads)?
Old Jul 27, 2006 | 01:51 AM
BlueStang6's Avatar
BlueStang6
Default RE: Swaybars Question
ORIGINAL: orion6g
I'm considering getting the helwig sway bars but am worried as the roads where I live (Northern Canada) are fairly rough with quite a few frost-heaves in the roads and I'm wodering if sway bars would make the car want to "hop" more ovber bumps and especiall make the back end want to swing out in turns (on bunmpy roads)?
As a general rule, when a rear-wheel-drive car is equipped with both front and rear sway bars, the rear bar should have less stiffness/diameter than the front sway bar. Installing too large a rear sway bar can make the rear suspension so stiff that it will cause the inside tire to lift on turns, limiting rear traction. In a high speed corner, it will also increase the likelyhood of "snap" oversteer occuring if the upper control arms bind and cause a sudden increase in the car's wheel rate. You are purchasing a matched set (front/rear) of a well made piece of equipment. I think the Helwig front sway bar is adjustable so during winter months increase the front stiffness to reduce any oversteer tendancy; the car will be less squirrely and want to "plow" into turns rather than the rear end "want to swing out".
John
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
