Popping Noise with Eibach Sway Bars
HELP!!! I just installed the front and rear Eibach sway bars. They pop anytime I make a turn or go over a bump. Any suggestions as to how to remedy this problem? I tried finding additional troubleshooting information through Eibach, but didn't have any luck. Unfortunetly, I don't speak German.
ORIGINAL: LocoStang06
if you didnt use locktight on the bolts you removed , when re-installing.. chances are the nuts backed off.. because every nut and / bolt is suppost to be a 1 time use only.. every time you remove your suppost to replace with brand new
KingRando
Oct 2, 2015 08:06 AM
