GT Take-Off Struts/Shocks
Old Sep 1, 2006 | 01:25 PM
mart_markin's Avatar
mart_markin
Default GT Take-Off Struts/Shocks
Can anyone tell me if the GT struts and shocks will fit the V6? I have the GT take-off sway bars installed (WOW) and they made so much of an improvement, I want to add the shocks/struts (and springs?) if they'll work. I would also like to know if this is a change I can make in my driveway and if it will need an alignment.
If anyone knows for sure, please let me know.
Thanks!!
Old Sep 1, 2006 | 03:45 PM
chrisc's Avatar
chrisc
Default RE: GT Take-Off Struts/Shocks
i know for sure they wont make your car sit properly, the weight of the GT is different in different areas
Old Sep 1, 2006 | 04:05 PM
dmhines's Avatar
dmhines
Are they different? I thought when I looked up the springs the 6 and 8 were the same ...
Old Sep 1, 2006 | 04:51 PM
HurricaneStang's Avatar
HurricaneStang
Ya the springs are the same but would that make the shocks/struts similar also?
Old Sep 1, 2006 | 05:40 PM
blackfoot's Avatar
blackfoot
its not worth your money.. if you gonna go with new springs and struts for improved handeling.. yourbetter off get an aftermarket.. like eibach..or steeda
Old Sep 1, 2006 | 06:10 PM
mart_markin
Thanks, just hoping for a little improvement for little money.
I will probably get the Saleen strut/shock package. Can those be installed easily enough (home and hand tools) and will I need to get an alignment?
Old Sep 1, 2006 | 06:15 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: mart_markin
Thanks!!
Unless anyone has the part numbers for the shocks/struts to say otherwise, I would think the GT has stiffer springs and the shocks/struts for those stiffer springs. Meaning they shocks/strust will be different. Your car won't sit any lower or higher with the GT springs but if they are a higher rated spring you will have a stiffer feel at all four corners.
If anyone has parts numbers for the shocks/struts on the V6 vs. the V8 post 'em. Traditionally the GT has had different components to give it a more aggressive suspension.
Old Sep 1, 2006 | 07:20 PM
blackfoot's Avatar
blackfoot
i can easily find that out for you in asplit second.. but im REAAAAAAAL lazy right now
Old Sep 1, 2006 | 07:21 PM
blackfoot's Avatar
blackfoot
check out the sticky at the top of the page for the install
NTO_GUY
Dec 24, 2015 11:23 AM
RRyder01
Jun 16, 2006 01:05 AM
04BlueGT
Dec 6, 2005 02:23 AM
clutchsix
Mar 21, 2005 07:14 PM
Disgustang
Feb 21, 2004 12:56 AM
