Tires on the rear
Old Sep 22, 2006 | 09:32 PM
LHANGLEY's Avatar
LHANGLEY
Default Tires on the rear
Looking at getting wider tires on the rear, but not sure how wide I can go safely. I currently have the Pirelli 235/55 17" all around.. If possible I'd like to keep those on the front. Any input would be great.
Old Sep 23, 2006 | 03:40 AM
Black2007's Avatar
Black2007
Default RE: Tires on the rear
Width is an issue for sure...but height also must be considered.. what ever tire you choose should be about equivalent to height of front tire to keep the car in balance...or the car will look like its "squatted" in the rear.
Old Sep 23, 2006 | 05:04 PM
Poco's Avatar
Poco
I've run 20x10's w/275-35-20's on the rear and clearance was not an issue.What can make matters worse is the wheel offset.
[IMG]local://upfiles/49197/42BA73B200624C2AB130F1812DCDDEB5.jpg[/IMG]
Old Sep 24, 2006 | 03:57 PM
06GT4RAD's Avatar
06GT4RAD
You do have to keep the overall height of the tires within a certain parameter or the ABS light will come on. I think it has to be within .2-.4
I run a 285 out back and a 245 up front.
Richard
Old Sep 24, 2006 | 07:07 PM
05Retro's Avatar
05Retro
I'm running the stock Perillis on the front with 275 50-17 on the rear. No problems what so ever.
[IMG]local://upfiles/13839/53954DE1835B47AD83BCBD68C8DB140F.jpg[/IMG]
[IMG]local://upfiles/13839/3606DE68062C4E50B959A37D93C945FE.jpg[/IMG]
[IMG]local://upfiles/13839/479D813B80084AADBFE75211D15906DF.jpg[/IMG]
mtgldr
Feb 3, 2024 09:00 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Sep 8, 2015 11:50 AM
M3hunter
Sep 5, 2015 03:42 PM
Sep 1, 2015 08:16 PM
