Does LCA relocation brackets change pinion angle
Old Sep 28, 2006 | 01:27 AM
mikesautocare's Avatar
mikesautocare
Default Does LCA relocation brackets change pinion angle
Does LCA relocation brakets change pinion angle? BMR Relocation brackets have two location points. For Eibach pro-kit which location is best? Upper or lower?
Old Sep 28, 2006 | 02:42 AM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: Does LCA relocation brackets change pinion angle
You don't need to worry about pinion angle unless you have lowered your car. At that point you would consider relocation brackets to change your weight transfer and instant center, and worry about pinion angle
Old Sep 28, 2006 | 11:10 AM
mikesautocare
The Eibach pro-kit lowers the mustang about 1.5 inches. I could be wrong but it looks like the pinion angle will be changed when you install the LCA relocation brackets because of the lower mounting locations.
Old Sep 28, 2006 | 09:35 PM
moosestang's Avatar
moosestang
If that were the case and you had your stock LCA's you would have to manually rotate the rear axle up or down to line up the mount. I don't know because I don't have the brackets. I'm still guessing it does not change the angle.
ORIGINAL: mikesautocare
Old Sep 28, 2006 | 09:49 PM
CrazyAl's Avatar
CrazyAl
The LCA relocation brackets DO NOT change the pinion angle.
Relocation brackets change instant center. (Google for "instant center" if you don't know what that is)
Adjustable control arms change the pinion angle.
They are two totally different things.
Old Sep 28, 2006 | 09:54 PM
moosestang's Avatar
moosestang
Well they could change the pinion angle if they moved the rear LCA mounting point down, but did not move it forward. That would cause the rearend to rotate upward. I'm guessing all the LCA relocation brackets move the mounting point down and forward to compensate for the greater angle.
mtgldr
Feb 3, 2024 09:00 PM
Gene K
Oct 21, 2015 11:37 PM
Oct 7, 2015 07:02 PM
DJ Piner
Sep 30, 2015 03:03 PM
Sep 17, 2015 07:57 PM
