Rear axle alignment?
Old Oct 4, 2006 | 04:39 PM
Timmay!!!'s Avatar
Timmay!!!
Default Rear axle alignment?
From what I've been told the rear axle is purposely misaligned just a little bit from the factory right? Anyone know exactly what those specs are? After I lower the car and adjust the panhard bar is it cool to align the rear axle perfectly straight or should I try to get it back to factory spec. Does anyone know why the rear axle was offset from the factory anyway? What does this do for handling?
Old Oct 4, 2006 | 05:41 PM
CrazyAl's Avatar
CrazyAl
Default RE: Rear axle alignment?
Some people have reported that their axle was offset from the factory. I doubt this was by design. I would chalk it up to variances in manufacture. As far as I know, if the rear end is offset slightly, there are no ill effects. As far as I can see in the Ford Service Manual, there is no information about a "proper spec" for rear axle alignment. (then again, the factory setup is not adjustable)
For what it's worth, mine was perfectly centered from the factory. After installing the Roush springs, it moved 5/16". I re-centered it using an adjustable panhard bar.
Old Oct 4, 2006 | 05:57 PM
Timmay!!!'s Avatar
Timmay!!!
Cool, I guess I'll align her dead center if I can. Thanks once again Al.
Old Oct 4, 2006 | 06:02 PM
The Ghost's Avatar
The Ghost
Backing up Al..I did not check mine prior, but after installing the FRPP springs mine was a whopping 1/16 off from center. I did not need an adjustable panhard bar.
Nov 10, 2015 11:39 AM
Sep 16, 2015 07:53 PM
Sep 10, 2015 08:39 PM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 1, 2015 08:16 PM
