bumpsteer
Old Nov 13, 2006 | 12:24 AM
thejucer's Avatar
thejucer
Default bumpsteer
I have a v6 06 and I used to have an 01 sts that would handle very well. I know it is a rough comparison and I would think the mustang would have an edge in terms of handling, but going around corners at highspeeds if I hit a bump or something in the road my steering wheel loses control for a split second, I think this is called bump steer. What can I do to stop this from happening... realistically and inexpensively... or atleast an explanation...
Old Nov 18, 2006 | 11:14 PM
powerProdigy's Avatar
powerProdigy
Default RE: bumpsteer
steeda bumpsteer kit $160. It corrects the geometry of the rack and pinion steering rods connecting to the spindles on a lowered car.
Old Nov 20, 2006 | 12:43 AM
sonicblue05's Avatar
sonicblue05
lower itand install sway bars, it wont happen as oftern, then get ate kit mentioned above if it still bothers you
Old Nov 20, 2006 | 01:27 AM
thejucer's Avatar
thejucer
and how much is all of this going to cost me... how much should i lower it.. can i fix this problem without lowering it
Old Nov 20, 2006 | 06:12 AM
chrisc's Avatar
chrisc
you might want to look at some strut options if you dont want to lower your car, but if you are only concerned about ride quality (and not right height) i have heard really good things about vogland springs lately
Old Nov 20, 2006 | 06:43 PM
thejucer's Avatar
thejucer
its not even ride quality i dont care if its bumpy or not, i want my car to handle better and losing control of steering over a bump around a corner is not okay with me. if i have to lower it i will but doesnt lowering a car cause a lot of other problems such as accelerated tire wear? i just want to improve the handling as inexpensively as possible
Old Nov 20, 2006 | 07:31 PM
Pyrat's Avatar
Pyrat
ORIGINAL: thejucer
Stangsuspension.com has a very good article on this subject. Here's the link
Sep 16, 2015 07:53 PM
Sep 1, 2015 08:16 PM
Timmay!!!
Sep 29, 2006 02:12 PM
NCGT
StangSuspension.com
Mar 2, 2006 04:50 PM
GT1999
Dec 29, 2004 06:15 AM
