Front sway bar installation question
Old Nov 26, 2006 | 09:21 PM
Ruc22's Avatar
Ruc22
Default Front sway bar installation question
I'm preparing to install my front and rear GT takeoff sway bars and did a little pre installation checking under the car. My question is, when I unbolt the two U-brackets holding the original sway bar, will I need to put a wrench or ratchet on the head of the bolts to hold it them place when I tighten the nuts? My reason for asking is it seems next to impossible to reach the bolt heads behind the frame. I don't want to get everything taken apart and then not be able to finish the job.
Old Nov 27, 2006 | 12:15 AM
nonstopred's Avatar
nonstopred
Default RE: Front sway bar installation question
theres no nuts, there just screws, you need a 15 and an 18 mm dd socket to do the job. make sure you have a good wrench there on tight. feel free to ask more qs about the front, pretty self explanatory i did in like 30 min
JonnyBlazeGT
Nov 3, 2015 01:10 AM
squishbang
Sep 7, 2015 07:57 PM
Mobiusone stang
Aug 24, 2015 04:08 PM
cedarmn
Aug 20, 2015 03:14 PM
01moostanggt
Aug 17, 2015 01:22 PM
