How will these do ?
Old Jan 5, 2007 | 09:41 AM
saud alzaabi's Avatar
saud alzaabi
Default How will these do ?
http://www.steeda.com/products/steed...springs_05.php
with these ?
http://www.steeda.com/products/steed...ble_shocks.php
or if u have better ones ? just the struts and shocks with springs..
Old Jan 5, 2007 | 11:01 AM
CrazyAl's Avatar
CrazyAl
Default RE: How will these do ?
The Steeda Ultra-lite springs are very good for street performance and "weekend race" applications.
Their shocks are OK, but I would rather have the Toicko D-spec shocks. The D-specs have the advantage of being adjustable. This means that you can fine-tune your settings to your driving style, conditions, and needs.
Old Jan 5, 2007 | 11:19 AM
saud alzaabi
ok if i got tokico D would the ultra ite springs fit ? and how many inchs will the car be lowered ?
or the lowering is adjustable?
Old Jan 5, 2007 | 11:43 AM
jay0heavenly's Avatar
jay0heavenly
ORIGINAL: saud alzaabi
yeah it would fit and the springs would lower it about 1 1/4 inches in the back and 1 inch in the front and the lowering is not adjustable; rather the "stiffness" is. Meaning you can drive it on full soft, full hard or anything in between, but the height would remain the same.
Old Jan 5, 2007 | 06:03 PM
saud alzaabi
nice .. thanks ..
and BTW .. lets say I got the adjustables, when adjusting them , should the car be lifted ? or its possible to tweak some screw thing by hand ?
Old Jan 5, 2007 | 06:46 PM
CrazyAl's Avatar
CrazyAl
It is a screw that you adjust by hand. It takes about 5 minutes to do all four. The front ones you get to by lifting the hood. The rears you can get to inside the trunk. VERY easy.
Old Jan 7, 2007 | 12:14 PM
scramblr's Avatar
scramblr
That's my combination, Steeda Ultralites and D-Specs. From the autobahn, through the neiborhood, to the track. Adjustments are limitless. You can't go wrong with this set up. I'd get some camber bolts ahead of time as well. You'll probably need them to get the allignment specs dialed in.
They're Eibach camber bolts part #81260 14mm. I called either Tire Rack or Discount Tire and they shipped them to me...$20. I just found them at Jegs.
SPC EZ Cam XR- Camber Kits for Domestic/Import Vehicles - JEGS
