V6 Tire Size Question
Old Mar 8, 2007 | 03:22 PM
SOHCman's Avatar
SOHCman
Default V6 Tire Size Question
Hi folks,
I see a lot of people sizing up rims from the 16" to 17, 18, 19 and even 20...
From what everyone says, the rims get heavier, performance decreases.
Not so much with a V8, but problematic with the less torquey V6.
Has anyone tried DOWNSIZING the rims to 15"?
A quick tire calculation shows:
Specification
Width
Sidewall
Radius
Diameter
Circumference
Revs/Mile
Difference
215/65-16*
8.46
5.50
13.50
27.00
84.80
747
0.00%
255/55-16
10.03
5.50
13.50
27.00
85.00
746
0.10%
255/60-15
10.03
6.02
13.52
27.04
84.94
769
0.14%
* is stock size
Now that I will be adding a T-LOC which will add traction bygoing from 8.5" of tread to 20" of tread, would reducing the weight of the tires be an acceptable option?
Tires and rims will be cheaper, and should net a slightly smoother ride. The 16" are pretty hard (I can't imaging running 20").
Anybody try this??
If you have, which spacers will be needed so I don't tag the inside of the wheel wells/suspension?
Thanks
SOHC
Old Mar 8, 2007 | 10:31 PM
my first mustang's Avatar
my first mustang
Default RE: V6 Tire Size Question
I dont think you can go smaller because of the brake diameter.
Old Mar 9, 2007 | 11:07 AM
DelStang86's Avatar
DelStang86
+1 on the brake clearance issues.. if you're looking for better performance, find some lightweight 16's and possibly low profile tires (for decreased diameter and weight).. the less rotating mass, the easier it'll be for those rear gears to put the power to the ground.
Old Mar 9, 2007 | 11:49 AM
SOHCman's Avatar
SOHCman
Good point.
Technically there's only 1/2" of difference, but if the 06 is designed to just clear the inside of the 16s then, yup, problems.
I'll check with the dealer for the exact specs on the brake clearance.
We can always measure it on the lift.
Thanks
SOHC
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
