Full BMR suspension
Old May 1, 2007 | 08:47 PM
The Ghost's Avatar
The Ghost
Default Full BMR suspension
OK I have had a full BMR rear suspension (udj. UCA, Solid LCA's, Lower relocation brackets, Adj, panhard bar) I don't seem to be able to keep enough grease in the control arms to keep them from squeaking. It is driving me nuts. I grease everything at each oil change. I have a very hard time forcing grease into the UCA bushing and that one seems to be the one making all the noise (at the body mount). Any ideas on type of grease (I use white lithium) or reason why the upper is nearly impossible to get grease into. Is there a mod to the bushing or do I just need more presure (nuematic is not out of the question) C'mon Big Al, I know you know what I'm talking about!
Old May 1, 2007 | 09:00 PM
techmanBDsStang's Avatar
techmanBDsStang
Default RE: Full BMR suspension
I have read with these bushing to use silicon grease.
Old May 1, 2007 | 09:02 PM
howarmat's Avatar
howarmat
s197 Junkie
I use the gease that BMR sells. I had read that you need a certain grease but I think it might be BS.
Old May 1, 2007 | 09:25 PM
techmanBDsStang
Yeah, I am not sure if it is BS or not. I didn't use the silicon grease, I used synthetic grease as that is what I had in my grease gun and the BMR instructions just said to use grease, nothing about what kind. And I read that silicon stuff after the fact.
Old May 2, 2007 | 03:08 AM
lrgnation's Avatar
lrgnation
It is not bs, the other types of grease create the problem the op has explained. Also other types of grease tend to detoriate the bushings.
Old May 2, 2007 | 06:44 AM
saud alzaabi's Avatar
saud alzaabi
ORIGINAL: lrgnation
man im living overseas and it will take a while + the grease will be expensive with shipping and stuff.. so is it alright to use the normal grease once or twice ?
Old May 2, 2007 | 11:39 AM
Rudiepoo1's Avatar
Rudiepoo1
Didn't the new parts come with the specific needed grease? I just ordered BMR's level 2 rear control arm package and changed the lowers to the Billet with poly and the last thing I want is problems. Another question is everyone changing out the bolts/nuts for the lowers and using new Ford parts? I've heard these are only one-time use.
Thanks
Old May 2, 2007 | 11:52 AM
howarmat's Avatar
howarmat
s197 Junkie
I have heard they are a one time use bolt alsobut not sure. And no you need to buy a tube of grease yourself from BMR site.
Old May 2, 2007 | 12:13 PM
offrdmania's Avatar
offrdmania
the squeeking is coming from a Delrin bushing. And yes, the grease that they are providing is formulated to work with that material.
On the bolt, most likely it isnt a one time bolt but instead a one time nut. Sometimes companys use a oblong threaded hole which clamps down on the bolt, ie a lock nut. Some lock nuts will stretch after one use so their clamping power is comprimised after that.
Old May 2, 2007 | 12:29 PM
howarmat's Avatar
howarmat
s197 Junkie
ORIGINAL: offrdmania
+1 I didnt think of that but that nut is probaby the weak link.
