lca reloaction bracket?
Old May 31, 2007 | 11:57 PM
hotairgypsy's Avatar
hotairgypsy
Default lca reloaction bracket?
I have a set of spohn adj lca's on the way and I was thinking about the BMR Bolt-on Control Arm Relocation Brackets. Will the spohn bolt right into them is my first question. Next would be are they needed for my application. Bottom line is I do not know if I am going to track for fun. I just want to have this car stick the best it can when i do play on the blacktop. what ya all think.
Old Jun 3, 2007 | 01:15 AM
leepinlen's Avatar
leepinlen
Default RE: lca reloaction bracket?
I have the exact same setup, works great,fits great, just cant get rid of one sqeak on one of the poly bushing.
Old Jun 3, 2007 | 01:39 AM
howarmat's Avatar
howarmat
s197 Junkie
a pypes o/r h pipe will take car of the sqeak!
Old Jun 3, 2007 | 03:48 AM
Stoenr's Avatar
Stoenr
ORIGINAL: howarmat
Hah, that just made my center stack rattle 10x worse. Even tho theres a tsb on it, I bet they plame the exhaust.
Old Jun 5, 2007 | 10:08 PM
likemike99's Avatar
likemike99
If you have not lowered the car the brackets are not needed. If you do drag they can help because you can adjust the LCA angle to get a bit more traction. For just street use you really only need them once you have lowered your car.
Old Jun 5, 2007 | 10:09 PM
likemike99's Avatar
likemike99
and yes the spoon LCA should fit fine
Old Jun 7, 2007 | 02:23 PM
Red06's Avatar
Red06
I have the Spohn adjustable (spherical / poly combo) LCAs with BMR relocation brackets and they fit just fine.
Old Jun 7, 2007 | 02:48 PM
hotairgypsy
how do you like the combo?
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
UrS4
Sep 30, 2015 10:13 AM
