Installed my LCA =)
Old Jun 15, 2007 | 07:51 PM
v8pilot's Avatar
v8pilot
Default Installed my LCA =)
Soo i still havent gotten my springs but i did get the adj LCA. and i got impatient and installed it today. the first one took 30 mins the second took 15 mins. The only hard part was trying to get the thicker side of the control arm into its bracket with the bushings. i found out that a rubber hammer works wonders. afterwards it took about 20 mins for the rest of the work. Installation was a breeze now i just got out of the shower about to go hop in and take it for a spin
Old Jun 15, 2007 | 08:12 PM
v8pilot's Avatar
v8pilot
Default RE: Installed my LCA =)
OMFG its insane the difference it made NOoo more hopping and i feel my butt getting pusshed into the seeat more :-) off the line also helped a little as in the back its more dead on i dont know how to explain it but its BETTER
Old Jun 16, 2007 | 04:21 AM
cryptic26djp's Avatar
cryptic26djp
glad to hear you are happy with it. i am considering the upper and lower for mine with a panhard bar but still uncertain. i think it would definitely help me put some of my power to the ground though.
Old Jun 21, 2007 | 05:07 PM
PLstang's Avatar
PLstang
I have several mods but have sent it to the shop for everything so far. I figured on trying to do the LCA and Panhard myself, as a first project. Sounds like you didn't find it all that hard?
Old Jun 23, 2007 | 09:15 AM
cryptic26djp
I am curious too. I just ordered the upper and lowers, panhard, and mounting brackets from Lethal Performance. Should get the parts soon and was wondering about the install. Anything else we should know about for this install?
Old Jun 23, 2007 | 04:46 PM
buddha211's Avatar
buddha211
Did you install everything with the suspension loaded? I've heard its not important for rod-ends but that you can f-up the poly bushings if you install them with no load on the suspension.
Old Jun 28, 2007 | 11:35 PM
rravolt's Avatar
rravolt
so the lca's were a good mod im thinking about doing the ones in mine along with a g-trac brace, panhard rod with brace and rear shock tower brace was wondering if these mods would make alot of difference and if the difference would be a good one, also with the rear shock tower brace i was wondering if nebody knew how hard it was to install one they say that some welding is required.
Old Jun 29, 2007 | 01:30 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
How would you know if the suspension is loaded? I want to know if myperformance shop did this accurately. Does it have to do with the lift? Thanks all.
ORIGINAL: buddha211
Old Jun 30, 2007 | 05:49 PM
shooter23's Avatar
shooter23
Loaded = there was weight on the car when they installed everything (car on the ground, no in the air with the axle hanging down...
I doubt that it would matter very much...but it would be easier to work on if the suspension was unloaded...
Old Jun 30, 2007 | 08:18 PM
buddha211's Avatar
buddha211
ORIGINAL: mAnYsTyLeS
The Ford shop manual suggests marking the shocks with a marker or grease pencil with the car on the ground, and making sure the marks still lineup before torquing the fasteners down.
