Got D-Spec's and Alignment!
Old Nov 4, 2007 | 09:57 PM
Denny Carlton's Avatar
Denny Carlton
Default Got D-Spec's and Alignment!
Hello everyone, This should be two different post, but I'm to lazy to do two different ones. First up is the D-spec's! I have all 4 sides to 4 turns from all the way tight. The front feels great and the rear feels maybe to stiff Any input to what I should set the rear setting to? Second up is a print out of my alignment! Before! After! I don't know what I'm looking at on the chart. Can someone come in and let me understand this tech-no. stuff. Thanks to all, Denny
Old Nov 15, 2007 | 03:31 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: Got D-Spec's and Alignment!
So it looks like you were out of alignment before the shocks and after you are in alignment for the mods you have done to the suspension. Looks like someone knows what they are doing at the shop that did the alignment. I apparently am following you around the handling section as this is the third post for your threads! Later J
Oh and try 5 turns out in the back to loosen it up a bit more but the springs and other suspension components might just be stiff as you have a better suspension setup for relatively flat roads (unlike the roads here in MI). JMO
Old Nov 15, 2007 | 09:12 AM
Denny Carlton
I did 7turns out front & out back, the car feels much more better now. I think I'll try 10 turns in another week or so. Thanks for looking out, Denny
baddog671
Jul 26, 2016 01:20 PM
winner99
Sep 30, 2015 07:04 PM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
