Tokico Adjustable D-Specs
Old Dec 5, 2007 | 07:52 AM
BartSimpson's Avatar
BartSimpson
Default Tokico Adjustable D-Specs
I have heard nothing but good things about these shock and I am interested in getting them. My question is how easy is it to "adjust" the shocks? I mean do you have to take it to shop every time you wantit adjusted, do you have to take the wheels off, put it on a lift, etc.? What is involved when adjusting these shocks?
Old Dec 5, 2007 | 09:53 AM
BlackBetty's Avatar
BlackBetty
Default RE: Tokico Adjustable D-Specs
There's a little shaft that comes up through the middle of the main shock shaft, and you just stick a tool in there (I think it's a hex key) and turn it. Apparently it takes about 5 minutes to do all 4. No shop necessary.
Old Dec 5, 2007 | 10:03 AM
Denny Carlton's Avatar
Denny Carlton
I inclosed some shots of the key that adjustthe shocks. Sorry about the dirty engine bay!
Old Dec 5, 2007 | 10:33 AM
jdmcbride's Avatar
jdmcbride
How easy is it to get all shocks set to the same setting? The pics don't show any type of scale for adjustability.
Also, I would be interested in seeing where you adjust the rear shocks.
Old Dec 5, 2007 | 01:00 PM
BartSimpson
Yeah, I was going to ask about the rears too. How do you adjust them? I have heard that they are difficult to get to unless you get some sort of attachment or special tool or something.
Old Dec 5, 2007 | 08:10 PM
Argonaut's Avatar
Argonaut
A little tool comes with the shocks, you can see it in the one photo above (a bit blurry). It has a mark on the top. You insert it in the top of the shart and first turn it all the way clockwise until it hits a stop. Then you turn it counter clockwise the number of revolutions to the setting you want. 1 rev would be very firm, 6 revs would be pretty soft.
Regards the rear shocks. The shafts stick up into your trunk. You can see the stock ones if you pull away the carpeting. Exactly the same as the front in that there is a shaft that you can insert the tool in. They do make remote adjusters for this. Its basically a 8 in long flexible tube with the key you insert into the shaft on one end and the **** on the other. They are nice to have but by no means necessary, you can just pull back the carpet to make the adjustment. Now if you had lots of stereo equipment (speakers, amps) in your trunk it may be a different story.
Old Dec 6, 2007 | 01:08 AM
androdz's Avatar
androdz
I ♥ Acer
It is very easy you just turn them completely to the right and just set them with turns to loose them out. you just count the turns and then start tunning until you got ur car neutral for the street. I did it to minimize the understeer. The rears you just move the carpet a bit and get access to it. The only problem I had is that I have the shaker1000 and I had to remove the shaker to adjust them.
Andrew
Old Dec 6, 2007 | 07:07 AM
BartSimpson
Now for the rears, does that mean you need to cut/drill holes in the floor of your trunk to install the Tokico's or is there something already there?
Old Dec 6, 2007 | 07:38 AM
Argonaut's Avatar
Argonaut
ORIGINAL: BartSimpson
No, you do not have to cut/drill/remove or mod anything. Go look in your trunk, pull the carpeting back on one side. You will see the top of the stock shafts. The D-Specs go in exactly the same place. Apparently, if you have the shaker 1000, they can be a little tough to get to, I have the 500 and I can get to them very simply.
Old Dec 6, 2007 | 10:01 PM
Denny Carlton
ORIGINAL: jdmcbride
The rear works the same way as the front, but your in the trunk of the car and pulling the side carpet to the side to get to the rear shock tower! I Maybe this can help you out! ps: If you need pix's of the way you use the key/tool for the rear, than please tell me and I'll do some shots no it.
