Sway Away
Old Dec 5, 2007 | 02:59 PM
Eddie64's Avatar
Eddie64
Default Sway Away
I recently purchased a front and rear sway bar off of a 08 GT What do I need to install these on my 07 V6,bushings diff bolts etc the package came with everything off the GT inc springs all for $27.00
Old Dec 9, 2007 | 11:33 PM
RedFire281's Avatar
RedFire281
Default RE: Sway Away
Re-use the bolts for the front sway bars. For the rear you will need four (4) bolts, washers and nuts: 8 x 16 for the for the end mounts behind the shocks. You will need two (2) bolts, washers and nuts: 12 x 65 for the end links (these should be threaded at the ends only because the end link bushings ride on the smooth center of the bolt). If you bought these at a dealer it will cost you over $25. Go to a good hardware supply store and get GRADE 8 (don't go cheap because of the tensil strength needed and rust protection) - should cost under $10.
Old Dec 10, 2007 | 08:39 PM
mattthecat's Avatar
mattthecat
anyone know where i can find just the links for the rear sway bar. i have a gt take off but no links
thanks
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
winner99
Oct 1, 2015 10:52 AM
Sep 16, 2015 07:53 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
RWHEELS
Sep 5, 2015 03:42 PM
