20s with a drop
Old Jan 29, 2008 | 01:49 PM
sweetlou69's Avatar
sweetlou69
Default 20s with a drop
so im going to be putting on the steeda 20" wheels. Anyone with 20s and a dropped mustang have any rubbings problems? ive only got a slight drop, the gt500 leveling kit. Just wanted to see if there were any rubbing issues
Old Jan 29, 2008 | 01:53 PM
brad281's Avatar
brad281
Default RE: 20s with a drop
Should be fine. What size front tires?
Old Jan 29, 2008 | 02:10 PM
05 Mustang's Avatar
05 Mustang
here you go...good luck with yours
[IMG]local://upfiles/50057/86A4E6C9F68C4A6DA09188978C044B1E.jpg[/IMG]
[IMG]local://upfiles/50057/C90CCE1538624DD681F0F8532433C060.jpg[/IMG]
Old Jan 29, 2008 | 02:20 PM
sweetlou69's Avatar
sweetlou69
255/35 275/35 20s
Old Jan 29, 2008 | 02:35 PM
brad281's Avatar
brad281
You'll be good with those. I have 245/40 fronts. Rear will look good with a drop.
Old Jan 29, 2008 | 03:00 PM
exx1976's Avatar
exx1976
ORIGINAL: 05 Mustang
I've been wondering the same thing...
That looks good! What size rubber you got on there? And what springs?
I just ordered a set of 255/35 and 285/30 on Toxic 20's.. I want to lower the car now, too.. Not a LOT, just a bit.. Like maybe 3/4" or so..
Old Jan 29, 2008 | 03:27 PM
sweetlou69's Avatar
sweetlou69
exx,
I did the vogtland gt500 leveling springs.
.8" in the front
1.2" in the rear
Old Jan 29, 2008 | 03:34 PM
05 Mustang's Avatar
05 Mustang
ORIGINAL: exx1976
Thank you.
255/35's all the way around
Steeda Sport Springs (but if I had to do it again, I'd go Eibach Pro-Kit...the back is still alittle high for my liking)
Old Jan 29, 2008 | 06:54 PM
ybnormal's Avatar
ybnormal
You should be good I used the frpp lowering kit almost 2 inches in front with 245 40 x 19
and 295 35 x 19 on 9.5 wide rims and have no rubbing issues from my tires to body. I live in the country and I do have a issue with my cervinies exhaust dragging the high spots in the country roads.[&:] going to switch to steeda springs to raise drop from 2 inches to 1 inch.
you can see some before and after shots of lowering at www.cardomain.com search ybnormal-gt good luck to you and you should have no problems.
Gene K
Oct 21, 2015 11:37 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
zanemoseley
Sep 6, 2015 12:58 PM
