Help BMR Adjustable UCA
Old Mar 7, 2008 | 06:13 PM
sevenleaf's Avatar
sevenleaf
Default Help BMR Adjustable UCA
Just a few questions on the BMR UCA. I never worked with an adjustable part before so I have a bunch of questions. The install looks simple enough but how should the UCA be tightend.
Right now it swivels back and fourth. If this wasn't adjustable I'd be done by now.
Do I use 2 wrenches after it's set to the proper height and tighten the poop out of it to keep it from moving then install it?
Any advise is appreciated.
Old Mar 7, 2008 | 08:07 PM
shooter23's Avatar
shooter23
Default RE: Help BMR Adjustable UCA
What pieces are you trying to tighten??
The jamnuts?
If your talking about the jamnuts, then yes, set the specs for the rear end and then after your adjustments, just use a couple wrenches an tighten the nuts that lock the adjuster.
If your talking about the bolts that hold the UCA on...then i dont know if you should be doing the install yourself haha, becuase its only going to get more complicated from here!!
If you have any questions you can PM me, I just finished installing UCA, LCA, PHB anda bunch of other suspension stuff last week.
Hopefully that helps!!
Old Mar 8, 2008 | 11:45 AM
sevenleaf's Avatar
sevenleaf
ORIGINAL: shooter23
The jamnuts?
You answered my question right there thank you.
Old Mar 10, 2008 | 03:18 PM
sevenleaf's Avatar
sevenleaf
Just finished installing BMR UCA and shesh! What a job 2 hours and I still have to torque everything down. The hardest part was getting the bracket bolts loosened. I have to take a 30 minute break I'm beat!
Old Mar 10, 2008 | 09:01 PM
sevenleaf's Avatar
sevenleaf
Finished the car up took it for a test drive didn't notice much but one of the jamnuts came loose so I tightend it again. Yippy
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
