Front sway bar replacement -Alignment needed??
Old Mar 21, 2008 | 08:54 PM
ccdguy's Avatar
ccdguy
Default Front sway bar replacement -Alignment needed??
Hi guys,
Dumb question... (Sorry about that in advance - I'm technically challanged)
I will be getting the stock front sway bar off my 2005 4.0L non-PP, and will be replacing it with GT take off front and rear sway bars. Will I need to do a wheel alignment after the origianl bar comes off and gets replaced with the GT bar, or does the replacement not change the front end a bit... If someone know, maybe you could let me know... I'd really appreciate it. Thank you in advance...
Old Mar 27, 2008 | 10:17 AM
Norm Peterson's Avatar
Norm Peterson
Default RE: Front sway bar replacement -Alignment needed??
As long as you don't touch anything except the endlink connections (and the chassis brackets), no. The sta-bar does not control the front wheel geometry, only how far the car moves in roll.
Alignment (checking it, at least) is required only if you disassemble the suspension or steering linkages. Strut bearings, struts, knuckles (aka spindles),ball joints, control arms, control arm bushings, tierod ends kind of stuff.
Norm
Old Mar 27, 2008 | 03:15 PM
4Rowdy's Avatar
4Rowdy
I second that comment. A front alignment is not needed.
djbigskrilla
Sep 20, 2022 01:04 AM
inyadreems
Aug 21, 2015 09:10 AM
cedarmn
Aug 20, 2015 03:14 PM
01moostanggt
Aug 17, 2015 01:22 PM
defarmer
Aug 13, 2015 06:40 AM
