Cobra Sway Bars
if theyre from an S197 cobraa yes, all of the S197's have the exact same bodies and will have the same connection points. the only things that are different are the drivetrains, and aesthetics. same frame, body, etc...
The bars will fit but you will also need the GT500 brackets.
The attachment points are the same but the brackets and
associated hardware are different because of the different
size sway bars. You want the GT500 sways why? The V8 GT
sways on a V6 pony pack would be just right. The GT500 sways
would be way too stiff and maybestart causing opposite side
tire lifting IMHO.
tire lifting IMHO.
ORIGINAL: StreamlineStang
How much difference is there between the V6 pony Package Sways and the GT take off Sways, or is there a difference?
31.5MM front
none inrear [:@]
Pony
31.5MM front
18MM rear
GT
34MM front
20MM rear
GT500
??? font
???? rear
Please fill in these #s if you know them.
ORIGINAL: 07lane40
iread somewherethe front 6's are only 28mm. the GT dwarfs the V6 one. i took them off and set them side by side and the difference was HUGE.
ORIGINAL: 07lane40
hmm... well when i put it on i felta huge difference.. (did a test drive with the GT frontbefore putting the rear on)... maybe its thicker metal?...
Now cut them in half and compare the wall thicknesses then its apples to oranges.
