Steering Wheel Vibrating
Old Apr 13, 2008 | 04:11 PM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
Default Steering Wheel Vibrating
Just installed new rims and tires. My steering wheel vibrates at around 35mph, but the vibration decreases around 50mph. The steering wheel is aligned perfectly and my new tires are 255/45/18 front and 285/40/18 back.
The tires were shipped on the rims already balanced.
Is this just tires needing to be balanced, or could I have a worped rim? Pretty sure the wheel giving trouble is right front.
Old Apr 13, 2008 | 05:16 PM
Stoenr's Avatar
Stoenr
Default RE: Steering Wheel Vibrating
Did you remove the small clips that are on a stud holding the rotor in place?
Each rotor has one. These will cause the rim not to sit flush against the hub on some aftermarket wheels.
Also they could be off in balance, it happens.
These clips are not needed, only during assembly.
Old Apr 13, 2008 | 06:17 PM
Margarita Girl
I know exactly what clips you are talking about. Just painted around them.[8D]
But thanks, I double checked and I have plenty of clearance.
Old Apr 13, 2008 | 06:54 PM
$0c@lponiboi's Avatar
$0c@lponiboi
i had the same issue with my 2003 gt went to get it aligned and that didnt fix it turns out all it was, was the tires were not balanced properly i know you just go them installed but thats how i fixed my issue, hope that helped out
Old Apr 13, 2008 | 06:56 PM
jahudso2's Avatar
jahudso2
What wheels are those? They look awesome on your car especially with the painted calipers!
Old Apr 13, 2008 | 07:06 PM
Margarita Girl
I have to drive the car to work tomorrow and will call around for someone to hopefully do a quick balance on my lunchhour.
ORIGINAL: jahudso2
Thanks!
I searched for months looking for the size and offset (and price) with a chrome lip. [8D] They are AZA R9's (35mm offset) on Toyo tires, 18x8.5 rim 255/45/18 front and 18x9.5 285/40/18 back.
Old Apr 13, 2008 | 09:27 PM
drbobvs's Avatar
drbobvs
Are you saying your wheels have recesses around the lug holes on the back of the rim?? I've never seen that on an aftermarket wheel.
Old Apr 13, 2008 | 09:52 PM
Stoenr's Avatar
Stoenr
ORIGINAL: drbobvs
My CT-R's are all recessed, but I still remove the tabs to be safe.
To bad your not close MG, I'd tell ya to swing on by for a balance job
Old Apr 14, 2008 | 10:19 AM
Margarita Girl
Made appointment for 4 tires balanced and front end alignment.
Old Apr 15, 2008 | 11:25 AM
jwineco5's Avatar
jwineco5
Thats gotta be it, new tires and wheels shouldnt vibrate steering wheel..
